89 v6 Reluctant To Start After Rain/Snow
#1105209
09/04/19 02:46 AM
If it rains or snows and I don't run it that day the car is a bear to start the next day. No problem starting on dry days or cold days. I've replaced fuel sender, fuel lines, distributor cap/rotor
I'm thinking to replace the ignition coil next....or maybe the ignition relay switch??
What do the Sages say??
Re: 89 v6 Reluctant To Start After Rain/Snow
[Re: polar]
#1105210
09/04/19 11:20 AM
Did you replace the spark plug wires?
[Re: polar]
#1105213
09/04/19 11:06 PM
Hey Cheesy
Yep ...but this has been a Long (like forever) on going problem....not sure how long ago I put new plug wires in.....less than 7 years for sure....but didnt seem to make any difference that I recall
[Re: polar]
#1105214
09/05/19 02:20 AM
I had that problem on my 89 V6. There is an o-ring that sits between the distributor cap and the distributor body. There were only fragments of the original when I purchased the truck. The o-ring part number is MD611460. I opened up all the electrical connections and sprayed some contact cleaner/lubricant on the contacts. Once both of these were done, the hard starting in damp weather went away.
[Re: polar]
#1105219
09/05/19 09:48 PM
Hey Mark, Thanks for the reply! I had recently heard of that being a solution and when I replaced the Distributor cap/rotar....(just last week) I checked that O-ring and being that I bought and installed a new distributor just 8 years ago my o-ring looked to be in great shape.
I did clean off oxidation on the distributor body and greased the O-ring and where the distributor sits on the o-ring with dialectical battery grease. ....but that did Not solve my problem in any way...Ugh!!
When and Where did you buy a New OEM O-ring?? Also, you got a caliper to measure what thickness your O-ring is? I would like to compare to mine to see if there's a difference.
What were "all the electrical connections" that you cleaned and lubed and what cleaner/lube did you use??
[Re: polar]
#1105220
09/05/19 11:04 PM
I ended up measuring my distributor and bought an o-ring sized for that ID off of Amazon. M2.5x90 Viton
[Re: polar]
#1105221
09/06/19 01:15 AM
[Re: polar]
#1105224
09/06/19 11:35 AM
Good to know! Too bad it's not available!
[Re: polar]
#1105226
09/08/19 02:11 PM
