Twin turbo 6g72 swap #1105451 01/13/20 08:11 PM
L
Loganshero Offline OP
Hi guys new member here. I'm planning on doing a twin turbo swap into my 94 3.5DOHC. From searching around it appears it can be done. I'm hoping to hear from someone with first hand experience doing this and what the main obstacles will be. I'm planning on using ecu and wiring harness from 3000gt. Understand probably modify accessory brackets, engine mounts, replumb turbo and cooling. Thinking the oil pan will probably hit front diff. Is this a bad idea? Any suggestions would be appreciated. Thanks guys
Re: Twin turbo 6g72 swap [Re: Loganshero] #1105453 01/15/20 07:47 AM
Welcome to 4x4wire!
Are you planning to keep your rig smog legal? Your location says Cali.
Steve Myler will have some good tips, as he's done a 6g75 into a Mighty Max.
Re: Twin turbo 6g72 swap [Re: rxinhed] #1105454 01/16/20 02:20 AM
L
Thanks I've enjoyed reading countless threads on here and other forums. Lot of knowledge on here. I'm not trying to keep it smog legal. I'll pay a little extra every couple years to get it to pass. I pulled the motor today and realized just how tight my motor sits in bay. Seeing as noone seems to have done the TT 6g72 swap I'm having second thoughts. I'm researching the 1uzef vvti swap and that's were I'm leaning towards now. This is our desert/dune rig so I'm looking for more hp
Re: Twin turbo 6g72 swap [Re: Loganshero] #1105456 01/20/20 09:22 AM
L
Ok I picked up a Lexus 4.0 v8 1uzfe and tranny. I would like to hear from anyone who has done this swap. I can get it mounted but I know it's going to be a pain to get new ecu wired up. Any advice would be appreciated.
Re: Twin turbo 6g72 swap [Re: Loganshero] #1105458 01/20/20 09:29 PM
plh Offline
Toasty is currently in process of doing a 1uzfe swap to his '98 - much of the info will transfer to your '94. His thread is on ExPo https://www.expeditionportal.com/forum/threads/toastys-98-montero-build.205201/
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Twin turbo 6g72 swap [Re: Loganshero] #1105462 01/22/20 09:44 PM
L
Awesome thank you
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6083 MB (Peak: 0.6787 MB) Data Comp: Off Server Time: 2026-10-24 07:22:29 UTC
