Lower ball joint GEN1 #1105502 03/14/20 06:45 PM
chadzeilenga Offline OP
Ok, IÔÇÖm convinced IÔÇÖm missing something here, but what is required to change the lower ball joint on a 4WD GEN1? I donÔÇÖt seem to have the clearance above it to remove as the CV is in the way.
Re: Lower ball joint GEN1 [Re: chadzeilenga] #1105694 09/16/20 04:57 AM
81for91 Offline
Not sure how late i am to answer here, but i just replaced all 4 ball joints on my 91. All you need to do is take off the wheel and remove the brake rotor and you should be able to access it. You will probably also need to remove/delink the tie rod ends. It's a good time to change those as well and they come quite cheap.
1991 Montero RS with LS bits
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5839 MB (Peak: 0.6320 MB) Data Comp: Off Server Time: 2026-06-04 12:02:39 UTC
