NP 235 T-case swap in Raider. ? #1105617 07/12/20 06:52 PM
TresMon Offline OP
Hey gang,
I've been looking for the archived tech article on how-to put a NP 235 T-case on a Mitsu manual tranny. (88' Raider) I'm waiting a 4:1 crawler ratio.
Thanks,
Tres
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
Re: NP 235 T-case swap in Raider. ? [Re: TresMon] #1105776 10/22/20 01:06 PM
TresMon Offline OP
Bump...
Help?
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Removed bump stops
4'x6' roof rack
100 amp alt
S.Winch hubs
Enormous RV battery
Re: NP 235 T-case swap in Raider. ? [Re: TresMon] #1105783 10/23/20 05:06 AM
Trailmonkey Offline
I was reading somewhere you may be able to bolt 2 transfer cases together. But cant say if the was stock Monty cases or swapped in cases.
If it was a divorced case like the Samurai's case is, that would be easy.
But im new to the mitsubishi team so i dont know much. Sorry i cant help.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
Re: NP 235 T-case swap in Raider. ? [Re: TresMon] #1105790 10/25/20 07:43 PM
The Aisin automatic is able to take the NP-231, but the stick trans is different. I've not read about stacked t-case in Montero. In the Toyota world, yes.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6003 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-10-24 06:25:30 UTC
