Re: Hazard Switch gone bad, no lights.
[Re: Trailmonkey]
#1105802
11/06/20 12:37 AM
That would be perfect. I can definitely use that.
P.M. me info.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door. Disabled Driver.
[Re: Trailmonkey]
#1105803
11/06/20 04:59 PM
Anyone else got broken hazard switches let me know. I messed up on mine but now know what to do and fix them, you wont be able to use the hazard flashers but all the rest will work.
Ill fix them for $15 plus shipping.
[Re: Trailmonkey]
#1105804
11/07/20 03:23 AM
Alan Casetta is getting about $115 for new hazard switches
PN: MB330277
[Re: Trailmonkey]
#1105805
11/07/20 01:30 PM
I just want an old one to fix up, set it to the hazards off position and epoxy that bad boy so it wont move.. Started to do mine that way but thought i could just jump the wires that the contacts made only. Removed the rest. Got the turn signals working but no brake lights. : (
[Re: Trailmonkey]
#1105811
11/17/20 12:33 AM
Well got my lights working, less hazard flashers. Simple mistake i made but thanks to Chad ive got it worked out. If anyone else has a bad switch, or no switch and needs their brake lights working again let me know, its a super simple 2 jumper wires and you will be back on the road even with no actual switch.
[Re: Trailmonkey]
#1106308
06/04/21 01:40 PM
I have the same problem so would greatly appreciate knowing the fix. Once you jumper will both brake lights and turn signals work again? Thanks,
'91 Montero RS unmodified
[Re: Trailmonkey]
#1106309
06/04/21 10:15 PM
There really aren't any. Facebook is killing forums because it's made for a 4th grader. So much information is lost on that stupid platform. If you wanted to run a bite to the back you could separate the brake light from the turn signal where it comes into the column switch. The guys using the JDM lenses do that to get a separate signal for the amber turn/red stop light.
[Re: JMQ12]
#1106311
06/06/21 11:38 PM
