What(?) to fix Raider Power Steering?
#1105831
11/28/20 09:39 PM
1987 Dodge Raider.
Power steering went out. It makes no noise at all. No pump screaming, nothing. Do I need a rebuilt pump to fix the power steering, or a rebuilt steering gear box, or both? The steering gear box doesn't leak.
Thanks. T
--Tres (John 14:6)
Black 87' Raider 2.6L/Webber 88 5 Speed Welded front,tight LSD in the rear Removed bump stops 4'x6' roof rack 10k. Lb. winch on receiver hitch/custom bumper 100 amp alt CB radio/AC inverter S.Winch hubs Enormous RV battery
Re: What(?) to fix Raider Power Steering?
[Re: TresMon]
#1105832
11/29/20 04:30 AM
Replace the pump and bleed. Check the fluid lines, too, and banjo gaskets.
[Re: rxinhed]
#1105837
11/30/20 12:06 AM
Thanks for all the help. Tres
--Tres (John 14:6)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.006s) Memory: 0.5928 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-10-27 04:02:07 UTCValid HTML 5 and Valid CSS
