Rating: 1
Page 47 of 52 1 2 … 45 46 47 48 49 51 52
Re: suzi the psychic [Re: rascott] #1105926 02/16/21 01:36 AM
well, learning curves are what they are...educating
Re: suzi the psychic [Re: rxinhed] #1105929 02/16/21 03:12 AM
rascott Offline OP
we should try and learn something new every day.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #1105939 02/18/21 06:43 PM
rascott Offline OP
minor update-
think i found the correct axle tube.
this came as a complete assembly, drum to drum, with a chewed third.
it is different from a 2wd rear - wider, larger brakes, w/ spring perches on top.
mabe some of this differential is useful....(?)
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1105943 02/21/21 05:15 AM
rascott Offline OP
further update-
stripped the rear axle assembly, hacked some brackets off of it, metalglued some brackets to it, and gave it a coat of paint.
it looks interesting, and mabe will work out.
i took another picture of the progress, and hope to have the picthing figured out soon.
as always, looking forward.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1105982 03/07/21 04:09 AM
rascott Offline OP
[Linked Image from hosting.photobucket.com]
my thanks to rxinhed for showing me how!
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1105991 03/08/21 02:57 AM
so happy my post was useful
Re: suzi the psychic [Re: rascott] #1106081 03/14/21 04:04 AM
rascott Offline OP
so the suzitoo project slowly moves on, and gets lot of coats of lookin' at.
i am learning about these axles(and how to make them fit), and finding parts that seem right.
been cleaning up some hubs for the front, and adding studs for the spindles.
everything is just a mock-up so i can put it on the ground.
still collecting parts before that happens, but i'm learning stuff as i go.
looks like i need to learn about driveshafts, and slip yoke eliminators.
can't believe these pics show.
it'll happen- looking forward
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106105 03/19/21 09:18 PM
rascott Offline OP
still trying to assemble enough parts- thought i'd have her able to touch the ground by now, but.....
some things look o k but are actually quite different. wheel hubs, for example.
think i have some correct ones coming, that will help.
i've been figuring out some brake hose runs, and will have to figure out the rear abs brake system removal(?).
i'm gonna eliminate the front backing plates.
suzitoo is far from driving anywhere soon, but still looking forward.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106116 03/23/21 03:41 PM
rascott Offline OP
got enough parts assembled in the correct order to put the front on the ground for the first time.
needs a lot of adjustments.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106119 03/24/21 12:32 AM
used a samurai front axle or toyota?
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.018s) Memory: 0.6523 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-11-01 11:43:16 UTC
