Rating: 1
Page 48 of 52 1 2 … 46 47 48 49 50 51 52
Re: suzi the psychic [Re: rascott] #1106121 03/25/21 07:38 AM
rascott Offline OP
i'm trying to fit some toyota axles.
i have suzitoo slowly returning to a more complete state, but just in a mock-up, as i find/make parts.
i totally misjudged what it takes to complete a front axle, and i'll still need to re-work the diffs.
gotta drill/tap the transfercase output shaft for mounting a flange, and get a driveshaft made.
never done that before.
made some little brakeline pieces to fit the calipers. the factory ones musta looked something like this?
[Linked Image from hosting.photobucket.com]
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #1106124 03/25/21 11:12 PM
looking great and you have both positive attitude and forward progress
Re: suzi the psychic [Re: rascott] #1106198 04/08/21 06:06 AM
rascott Offline OP
i've been making some sense of how this suspension will align.
being able to put it wheels down has helped, and i've been getting good at adjusting link lengths.
got the front aligned up, centered w/proper castor, and square w/the rear.
seems to be settling on her springs better, and i have mocked up the front driveshaft.
i need to modify/replace the front diff. flange- it has a funny bolt pattern, and 8mm bolt holes.
i think the rear is also ready to do a final measure for the driveshaft.
closer to function.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106240 04/20/21 05:58 PM
rascott Offline OP
got a rear driveshaft on order. that's exciting.
still need to do some drilling and tapping for the "slip yoke eliminator", something i have been contemplating for weeks, and may have to attempt a helicoil repair to the driver's knuckle(still unable to complete the front axle, but have stripped it, in anticipation of a functional refit. soon?).
dealing with ebay purchases of used toyota parts has proven disappointing. seems a real crapshoot- mabe it's usable, and mabe it's a shot piece of crap that costs a lot of$.
a bit of forward progress, even though it involves some disassembly.
i have been remiss in taking pictures- i shall try and correct that.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106255 04/30/21 01:59 AM
rascott Offline OP
got some important parts today-gears for both differentials, and what i expect to be the rear driveshaft.
the driveshaft looks kool, w/a double cardon(cv) joint for the transfercase end.
moderated on the gears, and went with 5.29:1.
i have begun "final" assembly of the front axle, and re-gearing a differential.
positive forward progress feels good.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106256 04/30/21 03:28 AM
there is an '81 {??} Toyota 4wd in orland at parts r us....might find your caliper mount there
Re: suzi the psychic [Re: rascott] #1106263 05/06/21 10:22 PM
rascott Offline OP
it got to the point where "final" assembly of the front axle could be done. i regeared the front differential by feel, and it allowed me to call all good.
now i'm doing the new and improved backyard gearchange on the rear differential. i intend to be more particular with this one, using what i learned from the first go around.
i did a search in the wire's toyota info and found a very good guide for the diffs- http://www.4x4wire.com/toyota/tech/gear_setup/
my thanks- i had watched utube flails- this made sense.
looking forward
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106264 05/07/21 02:48 AM
curious, the rotor looks solid?
Re: suzi the psychic [Re: rxinhed] #1106266 05/07/21 04:19 AM
rascott Offline OP
yes- rockauto specials.
they fit, and it's not a race car.
+ i don't know any better........ never saw any originals.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106283 05/15/21 07:50 PM
me, either, but presumed anything since about 1980 would be vented. shrug.
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.018s) Memory: 0.6555 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-11-19 23:53:45 UTC
