1990 Gen 1 steering gear box leak #1105938 02/18/21 06:42 AM
nvmonty Offline OP
Steering Gear Box Bottom shaft seal in a '90 LS is leaking.
An advice on seal kits?
90 LWB RS: 3 L/mt, JBaker springs, bushings, swaybars. KYB shocks tweaked, 134k mi, original owner.
97 LWB SR: SOLD Sep. 2014 131,006 mi: running boards removed, BFG 31x10.5 AT/KO tires, Air locker, AirLifts, KYB shocks, Cibie fogs, 3rd owner.
Re: 1990 Gen 1 steering gear box leak [Re: nvmonty] #1105953 02/25/21 03:14 AM
Pretty much any available, but try the Mitsubishi parts sources for OE.
Re: 1990 Gen 1 steering gear box leak [Re: nvmonty] #1105963 03/01/21 01:24 AM
Mudflap Offline
Had the same problem on my 87 Raider. Mine was leaking like a sieve, emptying the reservoir in a day. Pulled the steering gear to find there is an outer dust seal and an inner seal that requires the entire gearbox to be torn down. I bit the bullet on a rebuilt unit from AutoZone. price was $256.99 after returning the old steering gear to my local Autozone
Part # 5906
SKU # 10566
Limited-Lifetime Warranty
Notes: Remanufactured
87 Raider
4.3 GM
Edelbrock manifold
4-bbl Holley 390
700R Automatic
B & M Shifter
NP207 transfer case
31 x 10.50's
Superwinch 9500
Brush guard
IPF driving lights
Dual batteries
2000 watt inverter
Yakima roof rack
Hi-Lift jack
Two 20 liter gas can rack
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5924 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-06-05 09:17:47 UTC
