Page 1 of 5 1 2 3 4 5
Ignition Coil #1105990 03/08/21 02:34 AM
Trailmonkey Offline OP
Can any 12v ignition coil be swapped in ?
May need mine replaced and after looking around for them $$$ I thought the heck with that, why cant I just use an old canister type, Mitsubishi has two wires going to it, so does the others.
Anything special about the factory one over an aftermarket ?
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106000 03/08/21 05:13 PM
Found an aftermarket coil that fits the bill I think. For a Jeep JK.
1 ohm primary
12k ohm secondary.
Mine shows.
1.2 ohm primary
12k ohm secondary.
Shaped the same only the input plug is different. Thats easy i think, one is positive other is negative correct ?
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106001 03/08/21 05:14 PM
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106005 03/08/21 08:12 PM
Why do you feel there is need to change the coil?
Re: Ignition Coil [Re: Trailmonkey] #1106011 03/09/21 04:44 AM
Is that the reading you got from your coil, or what the OEM specifications are?
Re: Ignition Coil [Re: Trailmonkey] #1106014 03/09/21 06:23 AM
Oso Offline
If money is an issue, how about determining if the coil actually NEEDS to be replaced?
Go to mitsubishilinks.com and download the FSM (factory service manual). look in the ignition section. Pg 8-156 IIRC. That should give you the specs.
If it does need to be replaced then go to rockauto.com and buy an NGK for $15 or so.
Re: Ignition Coil [Re: Trailmonkey] #1106024 03/09/21 02:54 PM
Well the truck just shut off in the middle of the road, turned over but no spark, got it home and looked it over and no spark at all, removed the coil and bench tested and in the (dark) you could see a faint spark, coil was getting hot also. Seen signs of it arcing over to the laminates as well.
Nothing else on the truck explains its actions.
Got local parts store to order a replacement for only $40...
Hopefully nothing else down the line is also out.
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106028 03/09/21 07:34 PM
Oso Offline
You should get on Facebook and ask for help there. I think the general community will be more your speed when it comes to how to throw parts at an issue until it's resolved. HTH smile
Re: Ignition Coil [Re: Trailmonkey] #1106029 03/09/21 08:37 PM
How do you bench test an ignition coil?
Re: Ignition Coil [Re: Trailmonkey] #1106033 03/10/21 03:48 PM
I dont have FB. Done away with that years ago.
Look on YouTube and it will show you how, but put simply hook a 12v+ straight to the coil, a 12v- with a normally open momentary switch. Sparkplug hooked to the coil and 12v- hooked to the metal of the plug. .
Activate the switch.
Switch closed charges the coil, release and it discharges via the plug.
Disabled Driver.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6402 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-07-15 17:33:08 UTC
