89 SWB v6 - 4 wheel Alignment??
#1106486
09/26/21 04:39 PM
Hmm.........just thinking about alignment.... considering my locked up tie rod. Is all 4 wheels alignment possible..... and/or needed on 1st Gen. Raider/Monteros??
Re: 89 SWB v6 - 4 wheel Alignment??
[Re: polar]
#1106487
09/27/21 07:07 AM
Nothing you can adjust or change on the rear. Just lubricate or replace the front end parts that should have been greased all along, check the bushings in the pitman arm, set the toe in and move on. There are grease fittings on all major front end joints. They really do need to be lubricated at least every few decades.
[Re: polar]
#1106497
09/29/21 12:29 AM
Thanks Old Colt! That's my kind of maintenance! "lubricated at least every few decades".
[Re: polar]
#1106503
10/03/21 07:07 PM
Wish the lower controller arm bushings had fittings. Mine squeak.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door. Disabled Driver.
PHP: 7.4.33 Page Time: 1.122s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-05-26 05:58:14 UTCValid HTML 5 and Valid CSS
