Rating: 1
Page 52 of 52 1 2 50 51 52
Re: suzi the psychic [Re: rascott] #1106591 01/29/22 04:43 AM
rascott Offline OP
suzitoo is disabled for an oil pump replacement.
i ran her to san diego and back, to see if anything would break.
i had installed an oil pressure gauge, and realized that the pressure drops when the motor warms up.
i removed the oil pan, and tried to free the pressure relief valve in the pump, but the piston was frozen in a "venting" position.
the pump is driven by the crank, so i had to re-visit my failed attempt at removing the gorilla installed bolt on the crank.
i made a tool.
[Linked Image from hosting.photobucket.com]
worked like it should have(this is much easier then trying to jam the flywheel), and i found why the gorilla was concerned- the sprocket keyway is damaged(on the crank nose), and an odd sized key had been glued into the crank.
i will replace the pump, and put her back together.
still working on some rocker protection and rear bumper.
got a new fishing pole to play with.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #1106596 02/02/22 09:37 PM
rascott Offline OP
perhaps i have postponed the engine overhaul.
i have succeeded in replacing the oil pump, and now have better pressure at idle,
the pressure relief valve was seized in a venting position, but still produced enough pressure to keep the oil light off- if i had not put a gauge in, i wouldn't have known the difference.
used my new tool in the reassembly process.
still looking forward.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #1106703 06/09/22 03:36 AM
best of luck, suzitoo!!
Re: suzi the psychic [Re: rascott] #1106704 06/14/22 01:47 AM
rascott Offline OP
we shall run the luck.
gonna stretch her legs a bit on a real fishrun.
gotta see about tickling miss bitchy awake for an adventure.
i'm interested to see how this slushbox transmission will crawl.....
also a first real campability test.
should be back in a week.
some intentional.
kj6esv
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.017s) Memory: 0.6157 MB (Peak: 0.6885 MB) Data Comp: Off Server Time: 2026-07-09 13:32:03 UTC
