Page 2 of 3 1 2 3
Re: Oil Consumption - 98+ trucks #118507 05/15/03 03:16 AM
holger Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by BagaYams:
<strong>I will be changing to conventional/dino 10w-30 (which is what the owners manual recommends for the 2002 3.2L) from here on out.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">have you seen this recommendation youself ?
I have 2002 Rodeo too and my manual has nothing
about the oil base. It advices 5W-30, actially,
SH SEA rating - that's it. Actually, it is
almost illegal for a manufacturer to specify
an oil base: if an engine needs SH oil, it MUST
work properly on ANY oil of this quality,
regardless it's base material.
<small>[ May 14, 2003, 10:21 PM: Message edited by: holger ]</small>
Oleg
Deceased Rodeo'02 4WD.
Re: Oil Consumption - 98+ trucks #118508 05/15/03 03:20 AM
holger Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by fourwd1:
<strong>I'd also like to know why the 3.5 does use so much oil. Regardless of what Isuzu says, this isn't normal - AFAIK no other vehicle brand does this.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Actually, this is not true. Open a user manual for
BMW, Mercedes or VW, for example. You will be
surprised, especially by BMW's figures.
Remember that Isuzu makes trucks and their engines
are more loaded.
Mine uses very minor amount of oil, and the
consumption is getting less.
Oleg
Re: Oil Consumption - 98+ trucks #118509 05/15/03 04:27 PM
pinoy99 Offline OP
My first time running a poll and I guess I did it poorly but there are also limitations since there are only 2 questions/answers allowed.
The q&a are:
1)Model and Engine Type for 98+ trucks
a. Amigo,Rodeo,Rodeo Sports - 3.2L V6
b. Axiom,Trooper,Vx - 3.5L V6
2)Approximate oil consumption @3k miles
a. 1 quart
b. 2 quarts
I guess a better #2 answers are:
a: 0 - 1 quart
b: > 1
Folks can also be more specific by replying to this thread - vote or no vote.I'll try to get the results tallied in about a month or so. Thanks to all that participated.
Re: Oil Consumption - 98+ trucks #118510 05/15/03 06:44 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by holger:
have you seen this recommendation youself ? </font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Per page 8-17 of the 2002 isuzu rodeo manual:
" For temperatures above 0degF, SAE 10w-30 is the preferred viscosity grade. If cold-weather starting problems are encountered at temperatures below 0degF, SAE 5w-30 viscosity oils may be required."
Joel
Re: Oil Consumption - 98+ trucks #118511 05/15/03 07:04 PM
holger Offline
<strong> </font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by holger:
Joel</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">so, where do you see a notion about
'conventional dyno oil' ? I do not mind
10W-30, I mind the idea that 'dyno is
recommended by user manual'.
As for the 5W-30 vs 10W-30, all high-quality
5W-30 can be used everywhere 10W-30 can be used.
Oleg
Re: Oil Consumption - 98+ trucks #118512 05/15/03 11:27 PM
Holger- sorry you interpreted it that way <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> . I should have said "(which is the VISCOSITY the owners manual recommends)" I was NOT implying that the manual says you MUST run dino oil. The manual makes no dino or synthetic reference at all. It makes NO difference if you choose to use synthetic or dino motor oil - use whatever you like, so long as it meets the API specs & viscosity ranges per the manual, or risk voiding your warranty <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> .
Joel
Re: Oil Consumption - 98+ trucks #118513 05/21/03 05:20 AM
pinoy99 Offline OP
btt
Re: Oil Consumption - 98+ trucks #118514 05/21/03 04:53 AM
Survey says:
....little short on choices. My '98 Amigo 3.2 uses no oil between 3000 mile changes.
<img border="0" title="" alt="[Cool]" src="images/icons/cool.gif" />
Walt, Dirt Devils So.Cal.
Re: Oil Consumption - 98+ trucks #118515 05/21/03 02:58 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by pinoy99:
<strong>My first time running a poll and I guess I did it poorly but there are also limitations since there are only 2 questions/answers allowed.
The q&a are:
a. 1 quart
b. 2 quarts
a: 0 - 1 quart
b: > 1
Folks can also be more specific by replying to this thread - vote or no vote.I'll try to get the results tallied in about a month or so. Thanks to all that participated.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">OK, I voted now and put 1quart(aka 0-1 quart).
Cheers,
Con
Re: Oil Consumption - 98+ trucks #118516 05/21/03 08:46 PM
Could not get the poll to come up, so here is my poll feedback.
I have an '02 Rodeo, 3.2L with roughly 26Kmi. I use about 3/4qt. of oil every 3000mi. I just had it to the dealer for this to find out what was going on. I've never had a "Japanese" built engine use any oil. They told me it was normal. I find this hard to believe.
Speaking of oil, what kind of mileage intervals do most of you use for oil changes? My manual states 7500mi. All my previous vehicles typically ran the usual 3K-4Kmi interval. My wifes Volvo also states a 7500mi change interval. Have engine designs changed/improved that much?
Thanks,
Rich
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6336 MB (Peak: 0.7426 MB) Data Comp: Off Server Time: 2026-06-17 10:40:20 UTC
