87 4Runner - want F&R L/S's - what are my options? #13577 01/20/03 08:30 PM
DRM Offline OP
I know about the obvious TruTrac's, but what are the other options? I would assume to run a Supra in the rear, I would need to round up a V6 diff - correct? How about the front - anything out there?
Re: 87 4Runner - want F&R L/S's - what are my options? #13578 01/20/03 10:20 PM
DirtyHarry Offline
Toyota Moderator
Don't you look in the 4x4Wire Toyota Tech section? <img border="0" title="" alt="[Razz]" src="images/icons/tongue.gif" /> And I quote: "The Supra carrier will only retrofit into the V6 third member, not the more common 4 cylinder third member."
This still might be the most affordable option for you David, as unfortunately most limited slips cost as much as lockers new. Auburn Gear makes posi's for the front and rear, but they are expensive. TruTracs are expensive too for that matter. Is there a Gearless Locker or Quick-Lok application for Toyotas?
Isn't there a Supra 7.5" LSD application? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Re: 87 4Runner - want F&R L/S's - what are my options? #13579 01/20/03 10:24 PM
DRM Offline OP
thanks... and yes, I read that <img border="0" title="" alt="[Razz]" src="images/icons/tongue.gif" />
I was wondering if there were any other options out there. I tend to be on the cheap side of things - and since this is just for a little more traction for the DD I have no intentions of spending too much on anything.
I have run a lickright up front in IFS before, and for a DD that is NOT something I want for this use. Shoot, I would even settle for just a L/S for the rear - but right now that means tracking down a V6 diff AND a Supra L/S... and that starts adding up fast.
Re: 87 4Runner - want F&R L/S's - what are my options? #13580 01/21/03 02:27 AM
DirtyHarry Offline
Toyota Moderator
I guess that it costs just as much to make a limited slip as it does to make a locker. Your best bet then David (outside of horse trading for a V6 third) is to look for someone taking a limited slip out of their rig and replacing it with a locker.
Re: 87 4Runner - want F&R L/S's - what are my options? #13581 01/21/03 03:02 AM
Whats is your price range? I found my detroit true trac for as low as 315$ when other places charge up to 450$. I got mine from DTS Drive Train Specialists. In the long run the true trac will pay for itself because you don't need to run special synthetic$$ or replace any clutches when they wear out.
Re: 87 4Runner - want F&R L/S's - what are my options? #13582 01/21/03 03:15 AM
mosk Offline
There certainly is a 7.5" Supra LSD that will fit in the front diff, and they can usually be had for $50 or less at the local P&P.
These were the optional LSD's used in the Gen. I and Gen II Supras. You have to remove a little (1/4" or so?) of excess material on the ends of the front truck stub axles to get them to work with the Supra diffs, but otherwise i believe they are plug and play.
Easiest way to identify these diffs is from the axle code: you want Fxx3, where F = 7.5" and the final 3 = two pinion LSD.
Another identifier: the LSD's had a finned rear cover with a sticker that reads "LSD oil only".
HTH,
Jeff
<small>[ January 20, 2003, 09:18 PM: Message edited by: mosk ]</small>
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: 87 4Runner - want F&R L/S's - what are my options? #13583 01/21/03 04:22 AM
DRM Offline OP
Found a guy who has what he says is a L/S from an 89 Supra.... trying to get more info now, but does this sounds promising?
Re: 87 4Runner - want F&R L/S's - what are my options? #13584 01/21/03 04:24 AM
the best advice i can offer is to watch ebay. i got my truetrac for only $150 including shipping!! there are some really good deals to be found. good luck!
Re: 87 4Runner - want F&R L/S's - what are my options? #13585 01/21/03 04:43 AM
DRM look here <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=108485
He has the diff and lsd you need and it's for sale or trade.
Re: 87 4Runner - want F&R L/S's - what are my options? #13586 01/22/03 06:02 AM
DRM Offline OP
I emailed that guy, and *thought* I found a good deal on one only to find out the guy wants $250 plus shipping for a complete 8" Supra LSD diff <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" />
Oh well - I will keep looking <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
<small>[ January 22, 2003, 10:32 AM: Message edited by: DRM ]</small>
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6315 MB (Peak: 0.7502 MB) Data Comp: Off Server Time: 2026-06-20 05:39:13 UTC
