Re: anyone know how or where to rebuild a steering box [Re: LTC Don] #142038 12/16/06 10:22 PM
BillW Offline
Does anyone have a number or web address for St. Charles
91 LS Trooper 3.4 w/225k
BillWhitbeck@grovesigncompany.com
Re: anyone know how or where to rebuild a steering box [Re: BillW] #142039 12/16/06 10:39 PM
Canucklehead Offline
Google search.
How hard was that?
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: anyone know how or where to rebuild a steering box [Re: BillW] #142040 12/17/06 04:46 AM
trooperbc Offline
sure --
http://isuzu.stcharlesauto.com/Department-Parts.aspx
Phone: 800-727-8066
Fax: 636-441-4481
good luck
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: anyone know how or where to rebuild a steering box [Re: StinkBug] #142041 12/17/06 08:30 PM
RobG Offline
I still have yet to find a place that will rebuild the box.
and you haven't talked to Lakerat on PBB? Matt's a really helpful guy and I know he can rebuild Isuzu boxes as he went through mine for hydro assist.
-Rob
Re: anyone know how or where to rebuild a steering box [Re: RobG] #142042 12/19/06 02:06 AM
CPOM Offline
he probably fixed it 4 years ago <img src="/forums/images/graemlins/lol.gif" alt="" />
CHRIS
98 Amigo, 92 Pup
Re: anyone know how or where to rebuild a steering box [Re: CPOM] #142043 12/19/06 05:20 AM
Smiley Offline
Here's another link for all of the future searchers...
Planet Isuzoo Article #91: [b]'Rebuilding the Trooper Steering Box'[/b] - By Sam Jelinek
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: anyone know how or where to rebuild a steering box [Re: Smiley] #142044 12/23/06 04:00 AM
JohninLV Offline
I have the Helm manual and the 1 1/2 ton truck pitman arm puller it takes to pull the arm. Have rebuilt 2 differant boxes for my number 3 Trooper three times. All started to leak after 6 weeks. Finally traded mine in for an Autozone rebuilt unit. it blew the seals after 6 months. Got it exchanged thru Autozone no questions asked. I am only runing 31 inch tires with no lift. Mechanic friend says to use redline synthetic in them. No trouble with the other three 90 troopers. Be sure to bleed all the air out of the gear box and have your front wheels off the ground when you start up the engine and slowley work the wheel back and forth to get all the air out. It is really hard to remove the top seal around the steering wheel input shaft. The book says to cap one line and blow the seal out with compressed air pressure. Good luck doing that, if the seal is blown it wont hold any air pressure ether. If you scratch the shaft you will always have a leak. Best to have or build a spaner wrench to fit the nut on the back side of the input shaft bearing retainer so the old seal can be driven out thru the front.
If you drive it with a slow leak it could turn into a big leak and take out the pump when you drive home with tank dry. Been there done that also.
Good luck and merry Christmas
3 90 Trooper V-6's, 5 speed, 4.3L TBI, 31" BFG AT's, Fender Flairs, Bored intake, 1.6 roller rockers, MSD Coil, Jacobs Omni ignition. Heavy duty torsion bars, Rancho 9000 Shocks CAN'T SPELL, TO OLD TO LEARN, GOD BLESS YOU IF YOU CAN.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6243 MB (Peak: 0.7145 MB) Data Comp: Off Server Time: 2026-06-10 00:04:33 UTC
