after market gauges #15352 04/15/03 09:12 PM
ryno Offline OP
ok so i'm getting my 85 up and running. i want upgrade to aftermarket gauges. i plan on getting the 3 gauge pillar so i'm looking for 52mm gauges or 2 1/6" i was thinking oil pressure, oil temp, water temp, a/f, EGT? is it necesary?, boost i have but might replace.
now i think i ran across a egt/boost gauge. cool
now anyone know where to get a oil temp/pressure gauge
or a water temp/oil temp gauge
or a water temp/oil pressure gauge.
the dual gauges. the ones with two inside of one.
i don't think i need an EGT gauge, maybe not a oil temp gauge. but water temp oil pressure a/f for sure. i have a boost gauge already. this is for a supra turbo motor. boosting around 9 maybe more. i would like to know your guy's opinion on necesity of gauges and also if you know where to get any combo gauges
thanks much
ryan
89 4runner V6 33 MT/R GoodYear,the only way to go. open front and e-locker rear.4:88....Truck's needs are deeper than my wallet. so i got another truck <img src="/forums/images/graemlins/smile.gif" alt="" /> 85 4R I6 T 35 TRD rear dual case 4.56 lets go wheeling :P
Re: after market gauges #15353 04/15/03 10:25 PM
mosk Offline
I've always run oil temp and water temp through the same gauge, using two separate sensors and a DPDT switch (I also run LED indicators to identify one from the other, hence the DP). This works pretty well.
I haven't seen any of the temp/pressure combo gauges, but it does seem like it would be a good idea.
Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: after market gauges #15354 04/16/03 12:31 AM
ryno Offline OP
well i did some searching again today, using the word combo, i came up with more valid websites
TOS gauges
westach
i think these are for FORDS? :\
so i'm guessin westach and afew others are the only ones who make custom or dual gauges
i wonder if autometer makes them? i haven't seen any what about VDO? can't be that hard.any help is appreciated.. i'm now leaning towards westach. i heard good things about them over at pirate also
thanks
ryan
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5931 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-06-23 12:37:07 UTC
