Re: LSD Chatter #164773 09/19/01 08:40 PM
mustangjs Offline OP
Ok, I will flush twice with redline. How much $ per quart? Without looking up specs what is the capacity of the rear & front ( may as well do both) and replace the crush washers.<P>I will make sure to tip from side to side to get all the old stuff out of the rear<P>While I'm at it perhaps the Auto Tranny is due too. It has been about 30-40K on the last fluid change. just hope the weather is nice this weekend.
2000 WJ Stock
Re: LSD Chatter #164774 09/19/01 08:49 PM
Mitch Offline
The LSD makes the rear tires chirp when turning? Damn, I always thought it was from all those ponies stuffed into that little 3.0
89 Mitsubishi 2dr. V6, winch, Snorkle w/FF boot, Aisin's, sway bar discos, 15x8 rockcrawlers, 33X12.5 BFG MT's, KV85's, Snorkle install
94 Toyota x-cab, totaled
99 Dodge 2500 diesel, sold
Re: LSD Chatter #164775 09/20/01 11:57 AM
I have an '87 Montero 2.6L/I-4. How do you tell if I have the LSD? [img]images/icons/confused.gif" border="0[/img]
Re: LSD Chatter #164776 09/20/01 02:28 PM
Mitsuzu Offline
<BLOCKQUOTE><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><HR>Originally posted by sapper:<BR><STRONG>I have an '87 Montero 2.6L/I-4. How do you tell if I have the LSD? [img]images/icons/confused.gif" border="0[/img]</STRONG><HR></BLOCKQUOTE><P>Evidently it came as a package along with a suspension drivers seat and headlight washers. On mine there is a large obvious red(?)<BR>sticker on my drivers door jamb calling out for the friction modifier. Also supposedly there might be a sticker/tag on the rear diff/axles
Joe
Maybe for once, someone will call me 'sir' without adding 'You're making a scene'
Re: LSD Chatter #164777 09/20/01 07:48 PM
Movinfr8 Offline
Bill,<P>I just changed my front diff fluid (gen II) and made a note to myself to check the level at 44 ounces. It was kinda slow putting the oil in, as I had a long clear tube run up to the engine compartment and filled it from there. easier than trying to get the bottle tip in the hole. will be doing the rear today, and I expect about the same capicity (maybe a little more due to axles...) will update ya'll. <BR>Norm<BR>P.S. My Mobil 1 75W90 was about $6.50/Qt
87 raider 2.6
5-speed manual
Re: LSD Chatter #164778 09/20/01 09:12 PM
Movinfr8 Offline
Yep, even had to go back to AutoZone for more oil. <BR>82 ounces of oil in rear and 14 ounces of friction modifier! It was thirsty<BR>Gone to my Honeymoon <BR>See ya all!!<BR>Norm
87 raider 2.6
5-speed manual
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6149 MB (Peak: 0.6835 MB) Data Comp: Off Server Time: 2026-06-18 13:11:28 UTC
