Trailer hitch #180768 07/12/02 06:22 AM
RogerH Offline OP
On my 2000 Montero I want to install my Yakima (Hitch mount) bike rack, but all I have is the tow loop. I was going to purchase the U-Haul hitch but it looks like it mounts too low, (less departure angle). Is there any brand that mounts onto (in place of) the tow loop? I need a square reciever for the bike rack. It will actually tow a trailer in the near future. Thanks in advance!
2000 Montero, ARB bumper, TJM snorkle, OME suspension, Maggiolina Extreme RTT, BFG KM2's 33/10.5/15. ARB fr/rear lockers, 3.15 transfer case.
Re: Trailer hitch #180769 07/12/02 06:31 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by RogerH:
<strong>On my 2000 Montero I want to install my Yakima (Hitch mount) bike rack, but all I have is the tow loop. I was going to purchase the U-Haul hitch but it looks like it mounts too low, (less departure angle). Is there any brand that mounts onto (in place of) the tow loop? I need a square reciever for the bike rack. It will actually tow a trailer in the near future. Thanks in advance!</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">A better alternative is the kind of rack that mounts via a plate behind your spare tire. This rack hard mounts to the spare so you don't have excessive movement like you would get with a hitch rack.
<img src="http://www.sportsrack.com/catalog/BVG0093_lg.jpg" alt="" />
And since it's so high up, you don't need to worry about any real clearance issues unless your doing some major ledges or ascents/decents.
Best of all, it's only $149!!
http://www.sportsrack.com/Detail.bo...n=AND&start=1&total=4&no=631
<small>[ 12 July 2002, 01:32 AM: Message edited by: off-roader ]</small>
Re: Trailer hitch #180770 07/12/02 06:40 AM
RogerH Offline OP
Thanks! I already own the Yakima and had it on my Land Rover and with a few shims it never moved. Since I already own it...I would like to try to use it. Also, my bike is a full suspension so the hitch mount I have allows me to carry the bike with its funky geometry. Thanks though...I will keep this one in mind.
Re: Trailer hitch #180771 07/12/02 07:18 AM
CGuava Offline
i heard a Hidden Hitch is a good hitch for cheaper than Uhaul. Better design, stronger, and better departure angle.
try this thread from Isuzu board
Hitch Thread
Christian
88' Runner, SAS, Dual Cases, 529's, Locked, 37" MTR's, TR Beadlocks, blah blah.
Re: Trailer hitch #180772 07/12/02 07:23 AM
Kirk Offline
RogerH,
This is what I put on my '95. 2" reciever. It hangs down a little. Not too much though. http://www.zhub.com/ozarktruckoutfitters/listings/22.html
It says the hitch is for 92-98 but if the bolt pattern is the same it should fit just fine.
You can see a picture of what it looks like on my rig on my web page.
Trailer hitch
Hope this helps?
Do you have the tow loop that bolts on to the center of the frame? Want to sell it to me?
-Kirk
KJ6GVJ
Re: Trailer hitch #180773 07/12/02 01:38 PM
L
lites1995 Offline
I am also using the Sure Pull hitch that Kirk is recommending, and I give it a thumbs up. One of the things I like about it is that it is very easy to install and remove.
'89 LWB, V6, Auto, 31" BFG AT, ARB Locker, ARB Bumper, Aisin Manual Hubs, Dual Bouncy Seats
Re: Trailer hitch #180774 07/12/02 03:26 PM
I don't know about your truck, but I know John Baker sells a receiver hitch for Monteros that mounts to the frame plate on many monteros so you don't have that huge hitch mass under the bumper killing your departure angle.
Re: Trailer hitch #180775 07/13/02 05:25 AM
Try this out...
<img src="http://www.zhub.com/ozarktruckoutfitters/listings/22.jpg" alt="" />
This drops down but you could probably have a similar one made but with less drop. Just have a local fabricator make one since your only using it for your bike rack. It should be pretty easy... 2x2 tube steel and 3/8" plate steel.
FWIW, I too own a dual suspension bike (GT Team RTX & XRC-1) but they both have a top tube that I can clamp on with my rack. Both Yakima and Thule make top tube adapters for bikes w/out top tubes.
<small>[ 12 July 2002, 12:30 PM: Message edited by: off-roader ]</small>
Re: Trailer hitch #180776 07/13/02 12:08 AM
RogerH Offline OP
Many thanks to all! This is exactly what I was looking for.
Re: Trailer hitch #180777 07/13/02 12:15 AM
hotrod4x5 Offline
You can always take it off like I do, takes 10 mins.
Rodney,95 SR 3.5 L, Rancho RS 9000's, 31x10.5-15 Bridgestone Dueler A/T's, OEM Rear locker My Monty in action!
PHP: 7.4.33 Page Time: 0.013s Queries: 14 (0.010s) Memory: 0.6317 MB (Peak: 0.7393 MB) Data Comp: Off Server Time: 2026-11-16 08:49:54 UTC
