Re: here's the write up on my chevy 63" springs #19101 05/17/03 06:18 AM
Lou Bell Offline
Razz,
I wasn't real sure about a few things.
1. When I asked you about your pinion angle, you said that you used a shim to change it. Am I correct in assuming that the angle was pointed down?
2. I am assuming, because of your lack of vibration, that your new corrected pinion angle is near stock?
3. Are you still researching selling kit parts or are you nixing that idea.
Inquizitively,
LOU <img border="0" alt="[Nerd]" title="" src="graemlins/nerd.gif" />
'87 4runner 37x12.50x15 MTRs
SAS, 4.88's, rear+front e-lockers
4x4Him --- Christian 'wheelin
4x4Him National Forum
Re: here's the write up on my chevy 63" springs #19102 05/17/03 08:46 AM
RAZZMATAZ Offline OP
Hey Lou.
When I first set every thing up the my pinon was almost pointing at the t-case. It vibrated really bad so I trid a set of 2* shims, this helped a bunch but it still vibrated above 65mph.. so I installed a set of 5* shims!! They work fine but I have head that they will crack of work their way lose.. I dunno what the angle is I just know it works..
Front sping hangers & shackles. $85 + S&H
Upper and lower shock mounts $100 + S&H
U-bolt kit including 5/8" ubolts $95 + S&H
Most of these guys are about half that but I use a 1/2" plates and 5/8" U-bolts.
keep on truckin,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: here's the write up on my chevy 63" springs #19103 05/20/03 10:03 AM
Lou Bell Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> I dunno what the angle is I just know it works..
</font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I am assuming that your new pinion angle is paralell (or close to it)with the transfer case output shaft, this is why you lost your vibration. Rogers driveline angle page was quite an education for me.
I picked up some 63's tonight and I'm droolin'! <img border="0" alt="[Drunk]" title="" src="graemlins/drunk.gif" />
One last question: in your first post, the front looked pretty flexy (well, for toy IFS!).Are you running the Rockstomper travel kit or any other mods up front?
Re: here's the write up on my chevy 63" springs #19104 05/21/03 06:50 PM
Yea Lou, I'd say that the angle on the T-case and the angle of the diff are parallel..
As for the front I just removed ALL the bump stops!! Other than the Pro Comp stgII lift it's stock!
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
Re: here's the write up on my chevy 63" springs #19105 05/21/03 08:46 PM
Lou Bell Offline
I think under full compresion, the front upper ball joints will bind against the upper A-arm <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> . To remedy this, you can make http://home.off-road.com/~bibelheimer/4runner_susp.html#Increasing%20Lift%20Kit%20Wheel%20Travel or buy http://www.rockstomper.com/catalog/suspen/ifskit.htm front ball joint spacers, or use mega travel re-machined ball joints from Downey Off-Road.
Re: here's the write up on my chevy 63" springs #19106 05/21/03 11:07 PM
What do i get the 63" springs out of? Or did you order them from somewhere?
Re: here's the write up on my chevy 63" springs #19107 05/22/03 01:43 AM
moomba Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by 88RiverRunner:
<strong>What do i get the 63" springs out of? Or did you order them from somewhere?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
85 4Rnr SR5 - 35" Dick Cepek, Warn M8000, 364k miles
My superbike - 04 Aprilia RSV1000R
My BMW 8-series
PHP: 7.4.33 Page Time: 0.027s Queries: 14 (0.022s) Memory: 0.6234 MB (Peak: 0.7168 MB) Data Comp: Off Server Time: 2026-11-19 05:30:05 UTC
