ticking tach #192548 12/16/02 07:50 PM
kuhles Offline OP
Out yesterday doing mostly freeway driving and noticed that after running around for about an hour I heard a ticking that, because it seemed to vary with the speed sounded like the speedo cable. But further observation identified that it was a ticking between 2,600 and 3,000 rpm. So as I ran through the gears it would occur on and off. After cold start this am no ticking.
Has anyone heard of this? (no pun intended)
Charlie K.
'88 2.6 standard stocker in the flatlands "I love this truck"
Re: ticking tach #192549 12/17/02 04:51 AM
I get this too. I wasn't sure if it was the speedo or the tach. It went away, then came back. In fact, I had it come and go a few times (10 or 12 times). It is not there now (gone for at least 9 months) so I have not done anything.
Re: ticking tach #192550 12/17/02 05:53 AM
Its the speedo, next time it tics look at the actual needle you will see it bounce. If anyone knows a fix for this im game...bals
Re: ticking tach #192551 12/17/02 02:58 PM
kuhles Offline OP
Bals:
In order to eliminate the spedo I stopped the truck and requested my wife bring the engine to 2,600 rpm and it was evident, I lifted the bonnet and listened to the engine carefully so as to eliminate a valve tap or a heat shield which might vibrate at a certain frequency. It sounded like it was comming from the firewall area.
The whole thing makes no sence because the tach recieves pulses from the ignition coil.....right?
Goofy, but since it stopped it's hard to diognose.
Actually, I believe that each one of these trucks has developed it's own personality in the last ten years or so.
Friends are like that <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Charlie K
Re: ticking tach #192552 12/17/02 03:34 PM
We have a 91 Montero and I do remember that clicking noise from the dash that would only be between certain rpm's. One day I was in a bad mood and it started making the noise, so I smashed the dash really hard with my fist. It never made the noise since for the last 100,000 miles. It is definately coming from the tac though. there must be something under there that is rotating along with the tac signal from the coil. We also had another kind of clicking noise that was significantly different from the tac noise. This was from the Speedo. This is just an on and off thing, but I never looked into it. both will make noises though from time to time. with 200000 miles on our monty my speedometer probably needs lubrication or something. maybe its getting worn out and noisy. I just turn the radio up louder and i don't hear it.
Re: ticking tach #192553 12/25/02 04:20 PM
Scottie,I'd say you rule with an iron fist.Hit it agin.ha I just bought my '89 Raider.Just got balancer replaced after wobbl dance,now new style bolt is wobbling.Want to know how much trouble it is to tighten the torsion bars?Mine is bottoming out on the bump pads.I discovered that a v6 3.0 chrysler motor has the same crank gear,if anyone didn't know.Happy Holidays
'89 Raider V6 3.0 auto 2dr 31x10
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by scottie213:
<strong>We have a 91 Montero and I do remember that clicking noise from the dash that would only be between certain rpm's. One day I was in a bad mood and it started making the noise, so I smashed the dash really hard with my fist. It never made the noise since for the last 100,000 miles. It is definately coming from the tac though. there must be something under there that is rotating along with the tac signal from the coil. We also had another kind of clicking noise that was significantly different from the tac noise. This was from the Speedo. This is just an on and off thing, but I never looked into it. both will make noises though from time to time. with 200000 miles on our monty my speedometer probably needs lubrication or something. maybe its getting worn out and noisy. I just turn the radio up louder and i don't hear it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.003s) Memory: 0.6014 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-16 11:22:21 UTC
