toy e-locker in front ...SAS #19262 05/09/03 07:35 PM
anthony1 Offline OP
I found out that the Toyota elec. locker doesn't work in the front of solid axle.....Atleast when I try to put in the Downey cable adapter. <img border="0" title="" alt="[Mad]" src="images/icons/mad.gif" />
The spring purch and springs are in the way. I'm gonna put it in the rear instead. That means I'll have the whole third member with detroit and 4.56 gear for sale when I'm done with it.....not sure when though... <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: toy e-locker in front ...SAS #19263 05/09/03 09:04 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by anthony1:
<strong>I found out that the Toyota elec. locker doesn't work in the front of solid axle.....Atleast when I try to put in the Downey cable adapter. <img border="0" title="" alt="[Mad]" src="images/icons/mad.gif" />
The spring purch and springs are in the way. I'm gonna put it in the rear instead. That means I'll have the whole third member with detroit and 4.56 gear for sale when I'm done with it.....not sure when though... <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">that is very common knowledge, always do a search before droppin that kind of bank. high pinion e-locker is better up front anyways...
Re: toy e-locker in front ...SAS #19264 05/10/03 04:47 AM
why don't you just put the detriot 3rd member up in the front. they interchange front to back. i run a detriot locker up front on my 82 4x4 with no problems.
Re: toy e-locker in front ...SAS #19265 05/10/03 07:27 PM
spannky Offline
I have a 92 and am still looking for suggestions for my solid axle conversion but I am sad to hear the elocker wont work in the front what year / model crusers had the Hi pinnion elocker ? any other suggestions would be appreciated
Re: toy e-locker in front ...SAS #19266 05/10/03 08:19 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by spannky:
<strong>I have a 92 and am still looking for suggestions for my solid axle conversion but I am sad to hear the elocker wont work in the front what year / model crusers had the Hi pinnion elocker ? any other suggestions would be appreciated</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">WHOA THERE
e-lockers will most certainly work in the front, you just can't put the cable conversion on them. You have to use the stock electric motor to accuate it. High pinion e-lockers are bettedr for the front because of the reverse cut gears being stronger in front applications. High pinion e-lockers can be found in FZJ-80s...
Re: toy e-locker in front ...SAS #19267 05/11/03 04:06 AM
spannky Offline
Thanks I just purchased an e locker third member but havent gotten around to installing it . My back up plan was to use it in the rear . Any one know what ratio's the high pinion came in ?
Re: toy e-locker in front ...SAS #19268 05/11/03 06:53 AM
<strong>Thanks I just purchased an e locker third member but havent gotten around to installing it . My back up plan was to use it in the rear . Any one know what ratio's the high pinion came in ?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">IIRC High pinion e-lockers came from the factory with only one ratio, 4.10.
Re: toy e-locker in front ...SAS #19269 05/11/03 01:40 PM
spannky Offline
I WAS HOPING YOU WOULD SAY 4:56 I THINK I WILL GO THE 84 /85 SAS ROUTE
Re: toy e-locker in front ...SAS #19270 05/11/03 02:01 PM
surlynkid Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by 44Runner:
<strong> </font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by spannky:
<strong>Thanks I just purchased an e locker third member but havent gotten around to installing it . My back up plan was to use it in the rear . Any one know what ratio's the high pinion came in ?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">IIRC High pinion e-lockers came from the factory with only one ratio, 4.10.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">this is correct.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: toy e-locker in front ...SAS #19271 05/11/03 04:08 PM
cronustrd Offline
<strong>I WAS HOPING YOU WOULD SAY 4:56 I THINK I WILL GO THE 84 /85 SAS ROUTE</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">You can buy 4:56 replacement gears
2000 Toyota Tacoma TRD: 5" and 35s, Winch, Snorkle, Custom Sliders/Bumpers, Dana 44 and dual cases in the werkz...
1988 4runner: Formula Toy Meat...Got Sawzall?
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.009s) Memory: 0.6302 MB (Peak: 0.7533 MB) Data Comp: Off Server Time: 2026-11-16 17:34:44 UTC
