Page 2 of 14 1 2 3 4 13 14
Re: Specialized Part Number Repository *DELETED* #196205 03/21/03 12:27 AM
Juancho Offline
Post deleted by PHIL
98 Montero Sport LS with Off Road Package (ext. tire mount, factory locking diff)
Yokohama Geolander AT+II 31x10.5x15
Superwinch Manual Hubs
Kenwood head unit and Music Keg
Sirius Radio
Garmin Zumo 550 GPS
Black Widow Alarm with Remote Start
Re: Specialized Part Number Repository #196206 04/19/03 07:02 AM
Originally posted by pmontero:
Here are the part numbers for the NGK plugs, wires and O2 sensors for our trucks. When I called them, they suggested NAPA, NOPI, and any Parts Plus dealer as sources. Also, in the US and Canada, our models arrive 1 year after the rest of the world so a 1990 Montero is actually a 1989 Pajero.
'89 3.0 V6 SOHC
spark plugs - part no. BPR5ES-11# stock no. 7634#
plug wires - part no. ME61 stock no. 9545
O2 sensor - part no. 24129
'90-94 3.0 V6 SOHC
O2 sensor - part no. 24051
'95-99 3.0 V6 SOHC
spark plugs - part no. PFR6J-11# stock no. 2743#
plug wires - n/a
O2 sensor - n/a
'94-00 3.5 V6 DOHC/SOHC
spark plugs - part no. PFR5J-11# stock no. 4642#
plug wires - n/a
O2 sensor - part no. 24274 (DOHC only)
'83-85 2.6L
plug wires - part no. ME51 stock no. 9012
O2 sensor - n/a
'86 2.6 L4 G54B
spark plugs - part no. BPR6ES-11# stock no. 7133#
O2 sensor - part no. 24086
'87 2.6 L4 G54B
plug wires - part no. ME55 stock no. 9123
'88-89 2.6 L4 G54B
plug wires - part no. ME60 stock no. 9771
I transcribed these from their site. You can double-check your specific year by going to:
http://www.ngksparkplugs.com
Powell
Re: Specialized Part Number Repository *DELETED* #196207 05/20/03 01:15 AM
PHIL_ Offline
Re: Specialized Part Number Repository *DELETED* #196208 05/20/03 01:37 AM
Yellowhammer Offline
1991 Montero LS 3.0 5-Spd LWB 31" Bridgestone Dueller ATs on stock rims, tan/tan interior/exterior
1986 Isuzu Trooper 2.3 5-spd - partially disassembled, tan interior/dark blue exterior
Re: Specialized Part Number Repository #196209 05/21/03 02:55 PM
DaphneD Offline
NGK/NTK O2 sensor:
2.6L I4 (G54B) = P/N 24086 (~$45)
3.0L V6 (6G72) = P/N 24129 (~$65)
Same function as OEM at 1/2 the price. Got mine through Monarch Products, Inc.. Good people to do business with.
EDIT: BE AWARE that NGK's web page may not always display the correct part number as it has given me the wrong part number in the past. Better to call them at (877) 473-6767(prompt 1) to check again and be sure. (also be warned that their customer service hasn't been the friendliest or most intelligent in the past)
Re: Specialized Part Number Repository #196210 05/24/03 09:01 AM
JAVYPRO Offline
Column switch assembly for lights and wipers for 88 Montero with intermitent wipers and headlight washers.
Part number:MB543921
Price: $145 (incl. 6% tax)
Where: dealer
This guy at the dealer is awesome, he said he will help me find any hard to find part that I need; talking about service!!!
<img src="http://pics.montypics.com/javypro/2003-05-24/1053757953_Dsc00040.jpg" alt=" - " />
<img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Specialized Part Number Repository #196211 05/25/03 07:25 PM
MarkG Offline
Gen I, V6, front brake hoses.
Upper hose from frame to upper control arm. This hose is 1 inch longer than the stock Mitsubishi hose. Needed for trucks with trimmed bumpstops and longer shocks. Mitsubishi no longer carries the factory hose P/N MB238428.
NAPA Brakes P/N 38418
Lower hose from upper control arm to caliper. Mitsubishi no longer carries the factory hose P/N MB238425.
NAPA Brakes P/N 4138123
<small>[ May 27, 2003, 08:32 PM: Message edited by: MarkG ]</small>
Re: Specialized Part Number Repository #196212 06/03/03 04:36 PM
dwehbie Offline
Post deleted by RAY
Re: Specialized Part Number Repository #196213 07/11/03 09:28 PM
Selimyar Offline
parts needed during my recent transfer case (t-case) replacement, these are the parts the 88 service manual listed as non-reusable:
part number: MD739566
what is it: adapter gasket (between transmission and transfer case -- disassembly step 12 on page 21-14 in 88 service manual), this one felt like some kind of metal, maybe aluminum, as opposed to the old one which felt like paper
vehicle: 88 4-cyl 2.6L manual transmission Montero
price: $2.55 from Mitsu dealer
part number: MD716587
what is it: control housing gasket (between transfer case and gear shift assembly -- removal step 14 on page 21-43 in 88 service manual)
price: $2.10 from Mitsu dealer
part number: MD704159
what is it: housing cover gasket (between gear shift control housing and housing cover for the t-case shift lever -- removal step 12 on page 21-43 in 88 sevice manual)
price: $0.72 from Mitsu dealer
part number: MD704190, two of these needed
what is it: control lever gasket (one is between transmission control lever and stopper plate, other is between stopper plate and control housing -- removal steps 6 & 8 on page 21-43 in 88 sevice manual)
price: $0.90 each from Mitsu dealer
special note: MD701722 which is the part number for the spring pin (roll pin) used to attach the transmission change shifter to the transmission gear shift control shaft, turned out to be too small in diameter to replace the spring pin I took out, so I reused the old spring pin (disassembly step 7 on page 21-14 in 88 service manual) ... it was only $0.73 from the Mitsu dealer, so I didn't bother returning it
had an '88 Montero, then an '04 Rubicon ... sold 'em tho
Re: Specialized Part Number Repository #196214 07/13/03 07:26 PM
DaphneD Offline
[color:"red"]Sway-A-Way[/color][/b][b][color:"blue"]Powerbarz[/color][/b]
30% better spring rate than stock, can make for one rough road ride, but good for me because I like to jump over stuff! <img src="/forums/images/graemlins/smile.gif" alt="" /> Also beneficial if you have added weight up front (bull bar, winch, etc.).
'82-'89 Montero/Raider (D26mm x L50.38") = P/N [b]SWA1726
'90 - '94 Montero (D27.5mm x L53.80") = P/N SWA1736
'95 - Today Montero (D27.5mm x 51.40") = P/N SWA1739
I know that #1726 & #1736 are available at 4x4 Wholesalers (suspension:dodge). Expensive poop! It has been rumored that you can purchase directly through Sway-A-Way.
[color:"red"]Disc Brakes Australia[/b][/color] [color:"blue"]Longlife Gold slotted & cross drilled brake rotors[/color]
9/'88 - '92 3.0L V6 Pajero (D277mm) = P/N [b]DBA229 (specify options, i.e., slotting, cross-drilling, etc.)
10/'87 - '92 2.6L I4 Pajero (D258mm) = P/N DBA232 (slotted only)
EDIT IV: DO NOT order from Man-A-Fre! After waiting for 8mos and being consistantly told by thier customer service that my order had not yet arrived, I learned from DBA that MAF had not ever placed an order for my rotors. DO NOT order from Man-A-Fre!
EDIT V: As of March 2004, DBA does not have the Kangaroo Paw technology available in the longlife gold rotors for our vehicles, although I was told that they are slowly adapting their manufacturing to make the option available on all their product lines.
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.005s) Memory: 0.6548 MB (Peak: 0.7682 MB) Data Comp: Off Server Time: 2026-06-22 23:00:50 UTC
