Page 3 of 14 1 2 3 4 5 13 14
Re: Specialized Part Number Repository *DELETED* *DELETED* [Re: DaphneD] #196215 07/15/03 04:34 AM
DaphneD Offline
Post deleted by "PHIL the DESTRUCTOR/EDITOR"
Re: Specialized Part Number Repository [Re: DaphneD] #196216 07/17/03 04:37 PM
FranklinP Offline
High Side A/C hose, From Drier to high side. Small C-shaped.
MB239497 Tube,Liquid $23.22 Special order only.
(Thanks Pmontero) <img src="/forums/images/graemlins/kewl.gif" alt="" />
If you change the drier do not bend this hose it will break.
1989 Dodge Raider V-6, 33" Swampers.
Raider pics
Re: Specialized Part Number Repository #196217 07/17/03 06:31 PM
OK...I have the part numbers for both the hazard switch and the rear defogger switch is anyone needs them here they are:
Hazard Switch MB330277
Rear Defroster Switch MB521164
These are for and 88 Dodge Raider, but may fit others
Re: Specialized Part Number Repository #196218 07/18/03 12:40 AM
DaphneD Offline
[color:"red"]MAGNECOR[/color][/b] Race Wires:
(Magnecor retail pricing as of 5/2001)
'84-'96 2.6L I4 Montero:
Electrosports-70 (7mm) = P/N [b]4705 ($50.31)
Electrosports-80 (8mm) = P/N 4005 ($53.82)
KV85 Competition (8.5mm) = P/N 4505 ($86.42)
'89-'94 3.0L V6 Montero:
Electrosports-70 (7mm) = P/N 6714 ($63.38)
Electrosports-80 (8mm) = P/N 6014 ($67.41)
KV85 Competition (8.5mm) = P/N 6514 ($105.89)
As for everyone else's model: sorry, but you'll have to do the footwork. You can download their catalog at Magnecor
Unfortunately, they don't have online ordering, but you can get 'em direct from Magnecor through these old-fashioned methods:
Call: (248) 471-9505
Fax: (248) 471-9506
Email: [color:"blue"]mag@magnecor.com [/color]
Write:Magnecor, 24581 Crestview Court, Farmington Hills, MI, 48335
EDIT: Contact information updated 08/24/04
Re: Specialized Part Number Repository [Re: DaphneD] #196219 07/18/03 01:13 AM
DaphneD Offline
Gen I [color:"blue"]Old Man Emu[/color] suspension:
2.6L I4 Montero:
Fr Shocks = P/N N60G
Rr Shocks = P/N N56(LWB), N54(SWB)
Rr Leaf Springs (1.5" lift) = P/N OME22
Rr Leaf Spring Bushing Kit = P/N OMESB8
Rr U-Bolts = P/N OMEU54
Steering Damper (for models w/o P/S)= P/N OMESD17
3.0L V6 Montero:
Rr Shocks = P/N N62G
Rr Coils (1/2" lift) = P/N OME910
Get 'em just about anywhere.
Re: Specialized Part Number Repository #196220 07/19/03 05:43 AM
DaphneD Offline
[color:"blue"] ARB Air Locker [/color] locking differentials:
2.6L I4 Montero (GenI):
Fr Locker = N/A
Rr Locker = P/N RD05
3.0L V6 Montero (GenI):
Fr Locker = P/N RD110
Rr Locker = P/N RD46
The following courtesy of LeeN:
3.0L V6 Montero (Gen II W/ 5 spd):
Rr Locker = P/N RD25
3.0L V6 Montero (Gen II w/Auto):
Fr Locker = N/A
3.5L V6 Montero (Gen II):
Rr Locker = N/A
Air Locker Accessories:
ARB 12V Air Compressor = P/N RDCKA
Pneumatic line repair kit = P/N ASK001
Tire inflation kit = P/N PUKT
Re: Specialized Part Number Repository #196221 07/19/03 05:50 AM
DaphneD Offline
[color:"blue"]GenI Montero/Raider Safari Snorkel[/color]:
P/N = SS20HF
EDIT: The snorkel in this diagram is made to fit the OUTSIDE of the truck. The internals in the digram, however, don't match up with the internals of most of our Monties here in America and it will be UP TO YOU to figure out how to proceed from there. Some have cut through the inside fender to route the ducting more directly, while others have snaked it through the original intake opening and back again to the airbox. Either way works.
[color:"blue"]GenII Montero Safari Snorkel[/color]:
P/N = SS25HF
[color:"blue"]Gen2.5 Montero Safari Snorkel[/color]:
P/N = SS35HF
[color:"blue"]Mighty Max & D50 Safari Snorkel[/color]
P/N = SS625HF
[color:"blue"]7" Donaldson Pre-cleaner (3" neck):[/color]
Safari's P/N = 000-136-000
Donaldson's P/N = ???H000858???
*Can be ordered directly from ARB USA
Visit Safari Snorkel Systems for other applications or to see that cool video of the Isuzu floating downstream!
Re: Specialized Part Number Repository [Re: DaphneD] #196222 07/30/03 05:52 PM
ACL pistons for turbo 2.6 upgrade
ACL p/n P8107P
Ball Engine parts, Lilburn, GA (outside atlanta) 770-279-7881
Moog Steering Components #196223 08/11/03 04:04 PM
PHIL_ Offline
Here are the Moog Part numbers for redoing your frontend. Dodge has deleted the adjustor sleeve from their catalog, so an alternative can be had here...
(All Moog part numbers)
*Pitman Arm K9552 87-89
*Idler Arm K9738 87-89
*Idler Arm Bushing/Kit K9381 87-89
*Inner Tie Rod End ES2245R 87-89
*Adjusting Sleeve ES3065S 87-89
*Outer Tie Rod End ES2246L 87-89
PHIL
Re: Specialized Part Number Repository #196224 08/28/03 11:33 PM
Grandpa Bill Offline
Here's the info on the Harmonic Balancer/Pulley Assy. for the 3.0.
Since it's only available from the dealer, it's a bit pricey.
I got it from Walkers Mitsubishi's web site, web page .
The part number is MD 141468, the price was around $140 + $20 for Next Day Air (I really nneded it fast).
Bill Mattson, Certified Old Guy
Monty-less (right now)
Laura Mattson, Certifiable
Get in, sit down, BUCKLE UP, shut up and HANG ON!!!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6494 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-06-23 00:37:47 UTC
