Re: Specialized Part Number Repository
[Re: DaphneD]
#196225
08/29/03 02:02 AM
[color:"red"]Update 08/29/02[/color] I've since learned that the SS20HF is the right snorkle for our gen I bodies but the connection tubes to the filter housing are not correct. I've contacted ARB/Safari Snorkle about this and they say they won't update their kit because ARB hasn't asked them to and I suspect ARB won't ask them to because they don't sell enough kits in the US which is the primary market for this requirement. <img src="/forums/images/graemlins/shocked.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> [quote]Gen I [color:"blue"] Safari Snorkel [/color]: P/N = SS20HFVisit Safari Snorkel Systems for other applications or to see that cool video of the Isuzu floating downstream![\quote]
#196226
09/10/03 05:58 AM
Everyone with a 2.6l this is a must. LUNATI CAM SHAFT P\N 44201 SUMMIT RACING 1-800-230-3030 $150.00 to your door About 45 min to install BIG HP AND LOWEND TORQUE GAIN <img src="/forums/images/graemlins/kewl.gif" alt="" /> Works with stock springs .But you need adujstable rockers if you dont have them allready
#196227
09/10/03 05:03 PM
Rockers, lifts, bumpers, and other cool fabbed stuff from Roger Brown at 4Crawler Offroad
[Re: MontyMcV]
#196228
10/16/03 09:54 PM
NAPA Part numbers for some Mitsu parts. Some of these are not listed as Mitsu replacements but were cross-referenced by a nice parts guy in Peachtree City NAPA one slow afternoon.
3.0 V6 SOHC Gen I Parts
front crank oil seal - NAPA 14713 front cam oil seal - NAPA 13907 rear cam plug - NAPA B45682 valve cover grommets (2) - NAPA B 45729 upper radiator hose - NAPA 7737 lower radiator hose - NAPA 7946
Lower gearing P/NÆs
#196229
10/17/03 03:25 PM
This is thanks to Mr. Bishi and CAP510 (Note stock levels are from 4/23/03) û
Gen 1 2.6 (auto's & 5sp):- -front 5.29 MB185457 one unit left in ***an (no more production) my dealer maybe able to order it. -rear 5.29 MB241981 14 left ex stock in ***an.
Gen 1 3.0 V6 (auto's & 5sp):- -front 5.29 MB241981 14 left ex stock in ***an. -rear 5.29 MB598486 one unit in Oz, plenty ex stock in ***an.
Gen 2 3.0 V6 (auto's only) :- -front 5.29 MB831032 two units in Oz plenty ex stock in ***an. -rear 5.29 MB598486 one unit in Oz plenty ex stock in ***an.
And yes the MB241981 is the same part no for the 2.6 rear and the Gen 1 8" 3.0 V6 front.
For 4.90 gears to fit the Gen II 3.5 V6- (prices from Conicelli): -Front MR124860 - $375.23 -Rear MR124858 - $239.13 NOTE (29, March 2011): Discovered Conicelli Mitsubishi is no longer in business. For gears from Australia, contact Mr. Bishi. HeÆs stated before that for a small fee, heÆd purchase & ship gears.
For 4.88's in a Gen 1 V6, the 4.88's from the rear of a 4 cyl Gen I fits the front of the V6 Gen I, and the 4.88's for the rear of a 92-93 SR will fit the rear. The part numbers are -
Front 4.88 - MB527147 Lists about $370 from PAG auto Rear 4.88 - MB598487 Lists about $465 from PAG auto
#196230
10/21/03 10:09 PM
Factory Service Manual 1988 Montero Part # MSSP-004B-88
There are two volumes, make sure you get both!
#196231
10/29/03 05:33 PM
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's. 1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Part #'s for the Gen 1 Valve job
#196232
11/05/03 03:29 AM
Part numbers for the Gen 1 V6 valve job. These numbers pertain to the valve guides and seals that use the clips.
MD301619 Cylinder Head '88
MD024414 Valve Seat/Valve Guide Seat/Intake
MD110451 Valve Seat/Valve Guide Seat/Exhaust
MD000461 Valve Guide - Intake
MD185850 Valve Guide - Exhaust
MD185547 Snap Ring, Exhaust Guide
MD197467 Valve Guide Seal/Valve Seal
MD073398 Valve Spring
MD088811 Valve, Intake Valve All
MD088812 Valve, Exhaust Valve All
MD061895 Valve Keeper(lock) - Is For Half Of One Lock
1989 Toyota SR5 DLX SB 1995 Toy DX XTRA Cab 4x4 1989 Dodge Raider 3.0 V6, 5 spd, Michelin LTX series, bouncey seat 1988 Dodge Raider A/T w/Offroad Package 1959 Corvette 1977 Z28 1979 Honda CBX 1000 6 cyl
#196233
11/19/03 02:59 PM
#196234
12/23/03 08:25 AM
Micro bulb T-1 60mA 10,000 hr life For lighted console switches Part# 7219 Radio Shack Radio Shack - about $1.50 for two bulbs Dont throw out the rubber holder from the old one. You should also note how the old one is threaded through the holder. Here's what they look like pulled out of a couple different switches still in the rubber holder:
concreteprinter.com
