Page 5 of 14 1 2 3 4 5 6 7 13 14
Re: Specialized Part Number Repository [Re: bretwalda] #196235 12/23/03 06:07 PM
OKRED Offline
WISECO piston's, part number K555M925.
These are spec'd for the turbo engine, giving an 8:1 Cr and
a .054 over bore. There are no issues with head gasket clearance or valve clearance. They also come with rings and wrist pin "C" clips to convert to a floating piston which can alleviate some rod stress. At 400 for the set they are about twice as much as a good set of sealed power's but alot cheaper than other forged pistons. Also fantastic customer service from Wiseco. [Linked Image]
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Specialized Part Number Repository #196236 12/25/03 05:04 PM
DaphneD Offline
Engine Block Heaters available at your local dealership for like $30-$40.
2.6L I4 G54B Engines - P/N AMR4FH1X03
*I suspect that the P/N for the 2.6L has changed, although I don't currently have the updated P/N.
All other Monteros - P/N A0003FHX41 - Heater, Engine Block and retails for about $37.
Re: Specialized Part Number Repository #196237 12/31/03 08:09 PM
1993 3.0 V6 DSOHC
Oil pressure switch:
MD138993 (Dummy Light)
Rear Axil shaft inner oil seal:
MB290013
Rear Differential driveshaft seal:
MB16949
Transfer Case Rear driveshaft seal:
MD731708
Transfer Case Front driveshaft seal:
MD712012
Re: Specialized Part Number Repository [Re: DaphneD] #196238 01/02/04 02:54 AM
MarkG Offline
European Gen I Front Left Turn Lens
MB285911
Radiator [Re: DaphneD] #196239 01/04/04 03:16 AM
BAD87-2DR Offline
Phil you can delete this if its a dup.
Borrowed from Craqdweller :
part #: 1504 aftermarket radiator for a 92-94 Gen II (two different aftermarket companies make this unit). The overall dimensions are almost the same and it has a very thick two row core. Its two row, not three, but the core thickness is the same as the three row core that the shop will get to rebuild your OEM unit, so cooling efficiency will be nearly as good. You will have to redrill the mounting holes on the new radiator to fit your Gen I.
Active duty US Coast Guard helicopter mechanic (IA)
87 Monty
2.6
auto in progress
31X10.50 mudders
ARB
Warn 6000
Many hours of sweat and pain
Previously Badas87-2dr
Re: Specialized Part Number Repository [Re: DaphneD] #196240 01/07/04 06:39 PM
IN TANK FUEL GAUGE SENDING UNIT FOR 1990 LWB 3.0l 4DR
P/N is #MB571603
This is important as the parts counter person will most likely tell you this item does not exist, or is available ONLY with a fuel pump. Both are quite incorrect.
Will try to add the SWB and confirm other years soon.
Re: Specialized Part Number Repository #196241 01/07/04 07:31 PM
Gen 1 Radiator 4 cylinder:
CSF P/N 2035
Visteon P/N 9086
DPI-Universal P/N 1039
CSF has a lifetime warranty when purchased through Radiator Express 1-866-723-3977 (ask for Nick in Sales)
Cost (as of 1-6-04) is $102.00 including shipping.
Re: Specialized Part Number Repository #196242 01/10/04 04:22 AM
MarkG Offline
Part numbers for the Aisin hubs.
Front Hub Handle Seal: Toyota 43532-60010
This is the O-ring that seals between the dial indicator and the hub cover.
Front Hub Cover Gasket: Toyota 43531-60010
This is the gasket that seals between the hub cover and the hub body.
Front hub cover bolts:
Mitsubishi MB160712
Toyota 91641-80616 (Same as Mitsu bolts, cost less)
These are the bolts that hold the hub cover to the hub body.
Thanks to DougB for the updated Toyota part numbers
Re: Specialized Part Number Repository [Re: MarkG] #196243 01/15/04 07:18 PM
BottomFeeder Offline
Mitsu Axles and such:
http://www.overnightautoparts.com/
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Specialized Part Number Repository [Re: BottomFeeder] #196244 01/23/04 10:37 PM
Mitch Offline
Here is the part number for a 89 dodge raider V6 fuel guage sending unit. MB571767
Thanks Zombie
89 Mitsubishi 2dr. V6, winch, Snorkle w/FF boot, Aisin's, sway bar discos, 15x8 rockcrawlers, 33X12.5 BFG MT's, KV85's, Snorkle install
94 Toyota x-cab, totaled
99 Dodge 2500 diesel, sold
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6428 MB (Peak: 0.7506 MB) Data Comp: Off Server Time: 2026-06-22 13:11:00 UTC
