Page 6 of 14 1 2 4 5 6 7 8 13 14
Re: Specialized Part Number Repository [Re: Mitch] #196245 01/26/04 02:31 PM
BottomFeeder Offline
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Specialized Part Number Repository [Re: BottomFeeder] #196246 02/03/04 02:05 AM
NathanC Offline
For the guys wanting to do the V6 brake swap <img src="/forums/images/graemlins/kewl.gif" alt="" />.
Reman Calipers(L&R) NAPA 442-63069 & 442-63070
$64.79 + $55.00core (EACH)
These come complete with premium pads, hardware AND the brackets you need to bolt the calipers to your steering knuckles! <img src="/forums/images/graemlins/kewl.gif" alt="" /> The line brackets and hard lines for the calipers do not come with these however. I will get the Mitsu part# and prices for these soon <img src="/forums/images/graemlins/wink.gif" alt="" />.
Rotors NAPA 85926
$70.19
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Specialized Part Number Repository [Re: NathanC] #196247 02/03/04 05:29 AM
Idle speed stabilizer AKA ISCS, ISC, IAC, Etc...
Mitsu: MD628053 $384.00
Napa: 2-19243 $266.77
Gen 3 Suspension Lift... #196248 02/08/04 04:18 AM
OME (1-1/2" lift +/-) - http://www.arbusa.com/old_man_emu_suspension.htm
~$525-550, delivered (from usa).
front springs
914 std. / 915 HD
rear springs
917 std. / 918 HD
front struts
109S
rear shocks
110
i have complete technical specs for every OME spring made, if anyone is interested.
Pedders (2-1/2" lift +/-) - http://www.pedders.com.au
$unknown
front springs
7756 trackryder
rear springs
7757 trackryder
front struts
n/a?
rear shocks
9581 trackryder
Toughdog (4 Way) (2-1/2" lift +/-) - http://www.4waysuspension.com.au
~$1200, delivered (from australia).
front springs
tdc634
rear springs
tdc635
there are hd springs available. without a fulltime load they make +3.5", but can cause higher cv joint wear.
front struts
fcs4300
rear shocks
fc41148b
adjustable rear shocks
available Q4 '02 for all gen3's. model number unknown.
Re: Specialized Part Number Repository #196249 02/13/04 01:41 AM
nvmonty Offline
Parts for Gen I Montero wheel bearing repack (Feb. 2004 prices)
Freewheel hub:
retaining C ring
Mitsubishi MB092882
$3.43 each (dealer list)
shim set for above
Mitsubishi MB241229
$20.10 each (dealer list)
10mm cap bolt (8mm allen)
Mitsubishi MB29050
$6.12 each (dealer list)
Hub internal brake kit (2 pieces for each hub)
Mitsubishi MB290569
Dealer cost: $34
Dealer list: $87.49 <img src="/forums/images/graemlins/angry.gif" alt="" />(mark up more than 250%!!!!)
Wheel bearing:
inner grease seals
Mitsubishi MB 526395
$11.86 each (dealer)
locknut socket (aka spindle tool, locknut tool, etc)
Performance Tool W1270
$12.99 (Pep Boys)
same as Owatonna Tools OTC7270A,
Ford PN T878T-1197-A, 78-84 Ford 4WD F250/350 trucks,
73-81 GM 4WD K20/2500, K30/3500 trucks
fits 3/8 socket, has 6 pins, need to grind 4 off
spring scale
Fisherman's scale
$4.96 (WalMart)
large circular scale, reads , 0-50 lb,0-22 kg.
in 1/2 lb or .2 kg markings
90 LWB RS: 3 L/mt, JBaker springs, bushings, swaybars. KYB shocks tweaked, 134k mi, original owner.
97 LWB SR: SOLD Sep. 2014 131,006 mi: running boards removed, BFG 31x10.5 AT/KO tires, Air locker, AirLifts, KYB shocks, Cibie fogs, 3rd owner.
Re: Specialized Part Number Repository *DELETED* [Re: nvmonty] #196250 02/27/04 07:02 PM
DaphneD Offline
Post deleted by DougB
Re: Specialized Part Number Repository [Re: DaphneD] #196251 02/29/04 06:26 PM
PHIL_ Offline
BTT
Re: Specialized Part Number Repository #196252 03/18/04 05:41 AM
DaphneD Offline
[color:"red"]Mitsubishi Factory Service Manual P/Ns[/color] <img src="/forums/images/graemlins/smile.gif" alt="" />
Just walk into your local Mitsu dealer and give them these part numbers and they can order you a Factory Service Manual:
MSSP004B - Montero
MSSP003B - Truck
MSSP001B - Starion
...and add your model year to the end of the P/N to get the specific model year you're looking for.
EXAMPLE: If I wanna go to the dealer and get a manual for my '89 Montero, I'd put these numbers down...
MSSP004B89 - Service Manual, 89 Montero
Yep, it's just that easy! Of course the dealer price I've been quoted was like $133, so it might be worthwhile to shop around eBay. <img src="/forums/images/graemlins/wink.gif" alt="" />
Just thought it was good info to know. (currently working on a P/N source for Dodge)
P.S. - Credit for this post goes to NathanC for "discovering" and looking up the P/Ns and bretwalda for supervising. <img src="/forums/images/graemlins/kewl.gif" alt="" />
EDIT:
[color:"blue"]1989 Chrysler Import Service Manual: Ram Raider[/color]
I only have P/Ns for the '89 Raider Service Manuals (Chrysler). This includes both the 2.6L and 3.0L engines. I don't know the progression of numbers up to that model year, but I'm pretty sure that Dodge didn't market the Raider after '89 so it's all good. <img src="/forums/images/graemlins/wink.gif" alt="" />
81-370-9019 - Service Manual, '89 Raider (Vol I: Engine, Chassis, and Body)
81-370-9020 - Service Manual, '89 Raider (Vol II: Electrical)
Re: Specialized Part Number Repository [Re: DaphneD] #196253 03/22/04 04:30 PM
Mikuni carb depression chamber for '87 2.6L engine:
MD612713
Actuates the secondary by vaccuum.
Re: Specialized Part Number Repository #196254 04/13/04 04:15 PM
JoeyB Offline
Stock OE thermostat for my 1989 SWB 3.0
MD972903
Once I had a Raider, made it run. Brother can you spare a dime?
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6508 MB (Peak: 0.7626 MB) Data Comp: Off Server Time: 2026-06-22 18:13:06 UTC
