Page 7 of 14 1 2 5 6 7 8 9 13 14
Re: Specialized Part Number Repository #196255 07/30/04 07:50 PM
DaphneD Offline
[removed by DougH]
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Re: Specialized Part Number Repository [Re: DaphneD] #196256 08/27/04 09:10 PM
DaphneD Offline
Genuine Mitsubishi Parts *'89 3.0L V6 (and revised for other GenI 3.0L V6 models) [color:"red"]Throttle Body Overhaul kit[/color]:
(1) MD614299 - O-ring, Idle Air Control
**(1) MD614417 - O-ring, Idle Air Control
This gasket fits around the hole that the IAC servo motor plugs into.
(1) MD614306 - Gasket, Idle air valve body
**(1) MD614406 - Gasket, Idle air valve body
This gasket is for the valve body on the bottom part of the throttle assembly which is removed via 5 screws.
***(1) MD608806 - O-ring, Idle speed adjusting screw
This o-ring fits on the screw located at the top of the throttle body used to adjust the idle speed.
(1) MD151718 - Gasket, Throttle body
**(1) MD184046 - Gasket, Throttle body
This gasket fits between the throttle body and intake plenum. For vehicles with the heater plate adaptor recall, it will fit between the heater plate adaptor and the intake plenum.
And just in case your screws are frozen in place and you happen to be a new bolt enthusiast, like myself:
(4) MF240047 - Bolt, Throttle body (8x70mm)
**(4) MF240064 - Bolt, Throttle body (8x55mm)
(5) MF350060 - Screw, Idle air valve (5x40mm)
**(4) MD614416 - Screw, Idle air valve (5x??mm)
**(1) MF350051 - Screw, Idle air valve (5x??mm)
***(2) MD614285 - Screw, Idle Air Control servo (5x16mm)
***(2) MD614199 - Screw, Throttle Position Sensor (5x??mm)
(P/N MD600071 - Screw, TPS, has been discontinued)
*I should note that the P/Ns differ slightly from the model with the heater recall issue models and those that followed after. The main P/Ns provided above are for the throttle WITH the heater recall.
**For GenI 3.0L V6 other model throttle bodies (i.e., those NOT having the throttle heater plate recall; generally, most models after the '89).
***Same P/N fits ALL GenI 3.0L V6 models.
****If your truck hasn't been serviced by the '89 throttle heater recall, please investigate and/or inform your local dealer of this and they will take care of the work. Just in case they don't have it, the P/N for the heater plate ass'y listed in the recall is:
(1) MD153588 - Throttle heater kit
Dealer picks up the tab. <img src="/forums/images/graemlins/wink.gif" alt="" />
Please contact me if you need any info regarding this.
Re: Specialized Part Number Repository [Re: DaphneD] #196257 08/27/04 09:19 PM
DaphneD Offline
Genuine Mitsubishi Parts GenI (SWB/LWB) 3.0L V6 [color:"red"]Fuel Rail & Injector Overhaul Kit[/color]:
(1) MB554315 - O-ring, High-pressure fuel line
(1) MD604688 - O-ring, Fuel pressure regulator
(6) MD614813 - O-ring, Fuel Injector (inlet)
or
(6) MD604692 - O-ring, Fuel Injector (inlet) (Denso)
(6) MD614805 - Grommet (sheet), Fuel Injector
or
(6) MD604693 - Grommet (sheet), Fuel Injector (Denso)
(6) MD087060 - Insulator, Fuel Injector (outlet)
And if you're really ambitious...
(1) MD134230 - Harness, Fuel injector wiring ('89 model [color:"green"]$$$[/color])
(1) MD149431 - Harness, Fuel injector wiring (all other 3.0L V6 GenI models [color:"green"]$$$+$[/color])
Also visit RC Engineering, Inc. to have your injectors cleaned, tested, and balanced. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Specialized Part Number Repository [Re: DaphneD] #196258 08/27/04 09:25 PM
DaphneD Offline
Genuine Mitsubishi Parts GenI (SWB/LWB) 3.0L V6 [color:"red"]Intake & Exhaust Manifold Gasket kits[/color]:
(1) MD135158 - Gasket, Plenum
(2) MD168419 - Gasket, Intake Manifold (right & left)
(1) MD134703 - Gasket, Exhaust Manifold (right)
(1) MR404181 - Gasket, Exhaust Manifold (left)
(2) MB687002 - Gasket, Exhaust pipe (right & left)
And for Exhaust Gas Recirculation (EGR) equipped vehicles:
(1) MD119127 - Gasket, EGR valve
(2) MD149764 - Gasket, EGR pipe (upper & lower)
And if your EGR pipe has developed leaks may I recommend:
(1) MD141600 - Pipe, EGR ([color:"green"]$$$[/color])
(4) MD118580 - Bolt, EGR pipe (flange; 8x20mm)
P.S. If you have any intention of neglecting or disabling your EGR system, might I suggest you read this article from the Isuzu archives first.
Re: Specialized Part Number Repository [Re: DaphneD] #196259 10/02/04 04:27 AM
OKRED Offline
Seals for the V6 front diff(LSD SWAP).
Dealer
MT203648 PINION SEAL
MB 393883 DIFF OIL SEALS-2
NAPA
17773 PINION SEAL-1. $15.34
12785 DIFF SEAL(Special order no one has these)-2. $7.12
Order these well in advance I had to wait about a week for the diff seals.
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Specialized Part Number Repository *DELETED* #196260 10/05/04 02:32 AM
Tag Offline
Post deleted by Tag
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Specialized Part Number Repository [Re: Tag] #196261 10/11/04 12:43 AM
DaphneD Offline
[color:"red"]GenI Speedometer Gears[/color] to compensate for larger tire sizes:
MD705467 - Gear, Speedometer Drive (N=27)
MD705466 - Gear, Speedometer Drive (N=26): For 4.625 gearing and stock tires*
MD705464 - Gear, Speedometer Drive (N=24): For 4.625 gearing and 31" tires
MD705463 - Gear, Speedometer Drive (N=23): For 4.625 gearing and 32" tires
MD705462 - Gear, Speedometer Drive (N=22): For 4.625 gearing and 33" tires
MD705461 - Gear, Speedometer Drive (N=21): For 4.625 gearing and 35" tires
Other parts to go with that assembly:
MF472536 - Spring Pin, Speedometer Drive Gear (3x16mm)
MD701788 - O-ring, Speedometer Drive Gear (10.3mm)
MF520403 - O-ring, Speedometer Drive Gear Casing (35mm)
*Stock tire size is 225 or 235/75/R15
Re: Specialized Part Number Repository [Re: DaphneD] #196262 10/11/04 03:39 AM
KrzyDav Offline
GEN. I V6 Heater Hose Kit (2 hoses)
MB598095
dave h.
Re: Specialized Part Number Repository #196263 10/18/04 03:44 AM
KrzyDav Offline
Gen.1 V6 oil cooler check valve.
MD 356695
dave h.
Re: Specialized Part Number Repository #196264 10/18/04 06:23 PM
L
lu0902 Offline
<img src="/forums/images/graemlins/smile.gif" alt="" /> The item I am posting is a header made from Pacesseter. It is a long tube 4-1 header. This header will fit 2.6 Litter, 4 Cylinder Raiders/Monteros with evenly spaced ports. It is sold as a Kit and includes gaskets and hardware. I bought it online at www.summitracing.com for a grand total of 152.64. Part # PSM-70-1020
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6556 MB (Peak: 0.7705 MB) Data Comp: Off Server Time: 2026-06-22 18:11:45 UTC
