Page 8 of 14 1 2 6 7 8 9 10 13 14
Re: Specialized Part Number Repository #196265 10/23/04 04:18 AM
KrzyDav Offline
Steering box part numbers:
'83:
MB 501185
'84-'89 3.0 & 2.6 - SWB & LWB:
MB 350781
'90-'91 :
( note- possible 2 different ratios available)
MB 636331
'92-'97 :
MR 112835
(note-some differing internalparts between'92-'93 & '94-'96 & '97)
'98-'00:
MR 267974
dave h.
Re: Specialized Part Number Repository #196266 10/29/04 07:24 PM
RoryTek Offline
Ok got part numbers for trans pan gasket for the 5 speeds and backup light switch also
MD730709 backup switch
MD703796 Trans plate gasket
All from the dealer
Rory N6OIL
88'Monty 2.6l 2dr,5spd,Silver,2 bouncy seats,LSD
Most Wanted Synthetics
Re: Specialized Part Number Repository #196267 11/04/04 12:42 AM
87_Montero Offline
Sounds like you have some experience with Gen I 2.6 liter cylinder head gaskets. Would you recommend I install a "Head Gasket MD115646" in a stock 2.6 engine? If so, which manufacturer produces this gasket?
DDs:
Projects: 86 Ram50
Re: Specialized Part Number Repository #196268 11/26/04 06:28 PM
Tag Offline
Parts for AT filter and gasket change on a 89 v6. Provided to me by DougB
(2) MB896470 Filter Gasket
(1) MD609041 Filter
(1) MD951626 Pan Gasket
(1) MD951858 Drain plug Gasket
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Specialized Part Number Repository #196269 12/18/04 12:29 AM
TobyB Offline
rod bolts- md096144. $4.59 from the local Dodge boyos, $2.43 from http://www.mitsubishiparts.net. Guess how I got the part number?
It surprises me that these were so hard to find...
t
'89 V6 4dr- '4- Doris'
Re: Specialized Part Number Repository #196270 12/28/04 08:55 PM
CapnCrunch Offline
Superwinch manual hubs
D50
Montero/Pajero 83-90 (doesn't specify engine or trans)
MFR P/N 400543
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Specialized Part Number Repository [Re: CapnCrunch] #196271 12/29/04 08:49 AM
DaphneD Offline
GenI [color:"red"]A/T Throttle Control Cable[/color] (i.e., Kickdown Cable, i.e., Detent Cable)
2.6L I4
MD609348 - Cable, A/T Throttle Control
3.0L V6
MD609487 - Cable, A/T Throttle Control
Re: Specialized Part Number Repository [Re: DaphneD] #196272 01/14/05 01:17 AM
DaphneD Offline
[color:"blue"]GenI ARB Bull Bar[/color]
P/N 3434010
(thanks to MarkG for the picture <img src="/forums/images/graemlins/wink.gif" alt="" /> )
You'll have to call around to find one nowadays, but that's the part number. Also, if being fitted to the '89 and later models, the brackets will have to be refitted and welded to accomodate extra frame width.
Looking for ARB (11/09/02)
Re: Specialized Part Number Repository [Re: bretwalda] #196273 01/26/05 06:46 PM
W
whirlibird Offline
Micro bulb T-1 60mA 10,000 hr life
For lighted console switches
Part# 7219
Radio Shack
Radio Shack - about $1.50 for two bulbs
Dont throw out the rubber holder from the old one. You should also note how the old one is threaded through the holder.
Here's what they look like pulled out of a couple different switches still in the rubber holder:
Just for a bit of clarification and ease of finding this part:
The bulb is the #7219
RadioShack part number 272-1092 for a package of 2
'03 Nissan Xterra, 3.3L V6, Auto, Factory Limited Slip rear diff <img src="/forums/images/graemlins/smile.gif" alt="" />
'72 International 1210 3/4-ton flatbed w/ snow plow. Granny low anyone? <img src="/forums/images/graemlins/kewl.gif" alt="" />
'99 Toyota Tacoma X-cab, TRD, 2 1/2" lift, 32x11.50 MTR's on polished AE 058's. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Specialized Part Number Repository #196274 01/28/05 03:07 AM
Heater Hose (the small "S" shaped hose located between the intake manifold and the firewall) for 1987 2.6L
PN#: 21757
SKU: 0 72053 06066 9
Manufacturer: Gates
Cost: ~10.00
It's a direct fit and it saves a trip to the dealership.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6511 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-06-22 02:40:19 UTC
