Page 9 of 14 1 2 7 8 9 10 11 13 14
Re: Specialized Part Number Repository [Re: KrzyDav] #196275 02/23/05 12:32 AM
LRJ4x4 Offline
For a 88 Montero, 2.6
MB554503 : 1 : $55.69 Canister
> MB912914 : 1 : $6.38 not pictured, rear u bold
> MB584531 : 12 : $1.77 : 21.18 The 12 leaf spring bushings
> MB315806 : 1 : $34.24 The PS pump bracket
> MD110724 : 1 : $23.66 The heat shield
> MD161604 : 1 : $7.92 The heat riser tube
> MS450035 : 8 : $0.52 : 4.17 exhaust manifold washers
> MD000569 : 8 : $0.77 : 6.20 exhaust manifold nuts
Re: Specialized Part Number Repository *DELETED* #196276 03/11/05 10:51 PM
Post deleted by The_Full_Monty
Re: Specialized Part Number Repository #196277 03/15/05 01:02 AM
lordtrunks Offline
Couple part numbers for the front axle not the c.v's
all this stuff is on the passenger side.
dust seal(goes around bearing) MB160946
Dust cover MB160948
Outer bearing MB160662
axle Clip MB393911
Re: Specialized Part Number Repository [Re: lordtrunks] #196278 03/20/05 02:25 AM
2.6l balance shaft chain guides (don't know which is which, but here are all three):
md021156
md021111
md021114
Re: Specialized Part Number Repository [Re: JohnnyBfromPeoria] #196279 03/21/05 04:05 PM
DaphneD Offline
Clearwater Cylinder Heads current pricing for reman'd heads:
as of Mar '05
2.6L I4 (non jet-valved)
$375 +S/H
3.0L V6 SOHC
$175/ea +S/H
3.5L V6 DOHC
$265/ea +S/H
Your shipment comes with a prepaid return label to return your core(s).
California Owners: Catalytic Converter sources [Re: DaphneD] #196280 04/07/05 09:23 PM
After I failed my smog test (NO too high) I searched around for a replacement cat. As you would expect the dealer prices were extreme (out of this world) and so I did a search and learned that the California Air Resources Board (CARB) folks had a list of replacement CAT sources on their website.
They were mostly CAT rebuilders and the idea was you send them your OE cat and they rebuilt them by removing the old internals and installing new internals.
Here's the list with numbers and the costs they quoted me and any additional details they provided.
- Economy Smog 800-232-7670 $275
- Converter West 800-352-5030 $195 (takes 8-10 days)
- Help 800-544-4357 (nothing available through his sources)
- Miller Catalyzer 800-826-6615 $200 (takes a day or two)
- Belmar International (no other info)
I also learned that in CA, it's illegal for a salvage yard to sell you a used CAT. There may also be "legal issues" with selling/buying a used one via individuals. So if you're in CA and need a new cat proceed w/ caution.
In the end, I had a local shop install a non-mitsu unit which is even smaller so I actually have even less of a "clearance" issue (not that that's ever been a problem).
Cost w/ installation (they cut the OE inlet and outlet flanges and welded them to the replacement unit) was ~ $225 and I didn't have any shipping charges or installation issues to deal with.
HTH.
2.6 Cylinder Head Studs and Nuts [Re: off-roader] #196281 04/08/05 01:26 AM
Can't tell the difference between these two part numbers visually. They both are the same length and thread pitch:
Studs
MS401428
MD005317
Nuts:
Exhaust
MD092806
Intake
MF430005
2.6 Distributor O-Ring [Re: JohnnyBfromPeoria] #196282 04/08/05 01:28 AM
I think LRJ may have already posted it, but it's
MD619987
2.6 Fel-Pro Gaskets [Re: JohnnyBfromPeoria] #196283 04/09/05 10:52 PM
Intake manifold set
MS 90981
Exhaust manifold
MS 90995
Valve cover set w/ grommets and semi-circular plug
VS 50146 R
Mechanical fuel pump
70627
Head gasket
9116 PT
Rear camshaft circular packing (this is the one with the metal surround; it does not fit some heads and the rubber plug will have to be used in those cases - I don't have that number)
TCS 45848
Re: Specialized Part Number Repository #196284 04/12/05 02:41 AM
DaphneD Offline
[color:"blue"]Roger Brown Body Lift Kits[/color] w/ pricing guide (courtesy of Roger):
Body Lift Kit Pricing Info:
http://www.4crawler.com/4x4/ForSale/BodyLiftPricing.txt
Code
Mitsubishi Montero LWB (12 body mount mounts) Body Lift Kits:
  Kit:           Cost/1"    Cost/2"    Cost/3"
  B              $ 60.00    $ 78.00    $ 96.00  (Ult. blocks)
  D              $ 95.00    $113.00    $131.00  (Kit B + std. h/w)
  CLR            $ 12.00    $ 12.00    $ 12.00  (Custom color lift blocks)
  BS             $  8.00    $ 10.00    $ 12.00  (Per pair of bed spacers)
  HD             $ 15.00    $ 15.00    $ 15.00  (Upgrade Gr8 Hardware, rec'd on 2"+)
  EH		 $  5.00    $  5.00    $  5.00  (Extra pair of longer bolts if needed)
  P              $105.00    $105.00    $105.00  (Poly body mount bushings)
  Typical Kit    $ 85.00    $113.00    $131.00  + shipping**
                     (D)        (D)        (D)  (Typical kit contents)
Mitsubishi Montero/Pajero - Dodge Raider SWB (10 body mount mounts) Body Lift Kits:
  B              $ 50.00    $ 65.00    $ 80.00  (Ult. blocks)
  D              $ 80.00    $ 95.00    $110.00  (Kit B + std. h/w)
  CLR            $ 10.00    $ 10.00    $ 10.00  (Custom color lift blocks)
  P              $ 95.00    $ 95.00    $ 95.00  (Poly body mount bushings)
  Typical Kit    $ 80.00    $ 95.00    $110.00   + shipping**
Mitsubishi Pajero SWB (8 body mount mounts) Body Lift Kits:
  B              $ 40.00    $ 52.00    $ 64.00  (Ult. blocks)
  D              $ 65.00    $ 77.00    $ 89.00  (Kit B + std. h/w)
  CLR            $  8.00    $  8.00    $  8.00  (Custom color lift blocks)
  P              $ 85.00    $ 85.00    $ 85.00  (Poly body mount bushings)
  Typical Kit    $ 65.00    $ 77.00    $ 89.00   + shipping**
Notes:
[*] If you have trouble with the columns not lining up, be sure to select a "mono-spaced" font for your e-mail reader, such as "Courier"
[*] See above referenced file for description of the kit letters
[*] Kits B/D/F/H are mutually exclusive, that is kits F and H include kit D/B
[*] For ordering information, please provide a list of items desired and a shipping destination (as noted below).
(*) Optional at that height
(**) Zip code/country needed for shipping and sales tax calculation
With the list of items and destination a total price and ordering instructions will be furnished.
General body lift kit info:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Body Lift Kit Installation Instructions:
http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml
Add $2.00 for a printed copy included with your kit, or print your own copy
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6603 MB (Peak: 0.7709 MB) Data Comp: Off Server Time: 2026-06-23 00:44:01 UTC
