Page 10 of 14 1 2 8 9 10 11 12 13 14
Re: Specialized Part Number Repository [Re: DaphneD] #196285 04/13/05 08:04 PM
1989 Montero headlight washer check valve #MB141872
Re: Specialized Part Number Repository #196286 05/09/05 05:06 PM
DaphneD Offline
Get your engine oil, ATF, or gear oil analyzed through Blackstone Labs.
Re: Specialized Part Number Repository [Re: MarkG] #196287 05/23/05 05:32 PM
RockU Offline
What about Rear Break Hoses for 1989? <img src="/forums/images/graemlins/patriot.gif" alt="" />
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
Re: Specialized Part Number Repository [Re: RockU] #196288 05/23/05 07:09 PM
grass13 Offline
90' lwb ls 3.0 v6
timing belt p/n md111427 $94.75
timing belt idler pulley p/n md104578 $37.08
crankshaft pulley bolt p/n md138069 $2.65
didnt see these in there, delete if necessary <img src="/forums/images/graemlins/cheers.gif" alt="" />.
Re: Specialized Part Number Repository #196289 05/28/05 06:10 PM
W
wyleone Offline
TRW idle arm bushing set GEN I is 12709.
Re: Specialized Part Number Repository [Re: wyleone] #196290 07/13/05 12:54 PM
FrankR Offline
Bilstein Shocks for Gen1 V6 only:
B46-1336 Front
B46-1337 Rear
Bilstein Application Guide
Frank
Re: Specialized Part Number Repository [Re: FrankR] #196291 07/13/05 08:42 PM
W
wyleone Offline
I found the pt # to the Superinch hubs service kit.
#404401. It is $27.39 + 8.95 handling from Summit.
Re: Specialized Part Number Repository #196292 08/31/05 04:28 PM
franklynberry Offline
For the 1988 & later Gen I Montero/Raider, which uses a 'second generation' feedback carburetor:
Coolant Temp Sensor, small [13mm hex]: MD 091056 [$26.48 list]
Coolant Temp Sensor, large [17mm hex]: MD 069879 [$43.40]
Coolant Temp Switch: MD 102329
Feed Back Solenoid [mixture control, inside carb bowl]: MD 612831 [$246.72] [Vintage Auto; (877) 846-8243]
Slow Cut Solenoid [decel a/f ratio mgmt, externally
accessible on carb]: MD 612807 [$236.28]
Note: These two solenoids are NOT used on pre-'88 Mikuni
models, and I can't verify their use on Cal. models.
--frankb
'88 SWB 5-speed Megasuirt MS-II V3 Starion TBI N/A 650/950cc Injectors 4Runner Alloys 275-70R16
Re: Specialized Part Number Repository [Re: wyleone] #196293 08/31/05 09:16 PM
johnpsz Offline
Things to add from my 3.0 rebuild.
Woodruf Key MD008959
Pulley bolt washer MR994412
Crank timing pulley MD100568
Motor mounts MB436331
Front Flange - behind pulley assembly MD096940
Harmonic Ballancer/pulley assembly MD141468
Head bolts MD065959
I have seen a few of the others I needed on here. I also got a few others PN's at home that I didn't buy. Maybe when I remember to get them I will update more.
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
91 Montero RS LWB w/ 320k miles before rebuild, 900 down and its still kicking!!!
Re: Specialized Part Number Repository #196294 10/28/05 07:50 PM
weebur Offline
'87 Mitsubishi Montero front axle Snap Rings: MB092882. Shim Kit: MB241229.
Weebur
'97 Jeep Cherokee XJ, Country, Black/Gray Leather, 4.0L, 4WD Command-Track, AW-4 Auto, 3.55:1 Gears, PowerTrax No-Slip Locker, Hi Country Tow Brackets, Spectre Air Filter, 235X75R15 Goodyear Wranglers, 126K miles
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6470 MB (Peak: 0.7539 MB) Data Comp: Off Server Time: 2026-06-23 01:19:38 UTC
