Re: Specialized Part Number Repository
[Re: DaphneD]
#196285
04/13/05 08:04 PM
1989 Montero headlight washer check valve #MB141872
#196286
05/09/05 05:06 PM
Get your engine oil, ATF, or gear oil analyzed through Blackstone Labs. ![[Linked Image]](http://home.earthlink.net/~iamjackshead02/Case204456/204456%20-%20Oil%20Report.jpg)
[Re: MarkG]
#196287
05/23/05 05:32 PM
What about Rear Break Hoses for 1989? <img src="/forums/images/graemlins/patriot.gif" alt="" />
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
[Re: RockU]
#196288
05/23/05 07:09 PM
90' lwb ls 3.0 v6 timing belt p/n md111427 $94.75 timing belt idler pulley p/n md104578 $37.08 crankshaft pulley bolt p/n md138069 $2.65 didnt see these in there, delete if necessary <img src="/forums/images/graemlins/cheers.gif" alt="" />.
#196289
05/28/05 06:10 PM
TRW idle arm bushing set GEN I is 12709.
[Re: wyleone]
#196290
07/13/05 12:54 PM
Bilstein Shocks for Gen1 V6 only: B46-1336 Front B46-1337 Rear Bilstein Application Guide Frank
[Re: FrankR]
#196291
07/13/05 08:42 PM
I found the pt # to the Superinch hubs service kit. #404401. It is $27.39 + 8.95 handling from Summit.
#196292
08/31/05 04:28 PM
For the 1988 & later Gen I Montero/Raider, which uses a 'second generation' feedback carburetor:
Coolant Temp Sensor, small [13mm hex]: MD 091056 [$26.48 list]
Coolant Temp Sensor, large [17mm hex]: MD 069879 [$43.40]
Coolant Temp Switch: MD 102329
Feed Back Solenoid [mixture control, inside carb bowl]: MD 612831 [$246.72] [Vintage Auto; (877) 846-8243]
Slow Cut Solenoid [decel a/f ratio mgmt, externally accessible on carb]: MD 612807 [$236.28]
Note: These two solenoids are NOT used on pre-'88 Mikuni models, and I can't verify their use on Cal. models.
--frankb
'88 SWB 5-speed Megasuirt MS-II V3 Starion TBI N/A 650/950cc Injectors 4Runner Alloys 275-70R16
[Re: wyleone]
#196293
08/31/05 09:16 PM
Things to add from my 3.0 rebuild. Woodruf Key MD008959 Pulley bolt washer MR994412 Crank timing pulley MD100568 Motor mounts MB436331 Front Flange - behind pulley assembly MD096940 Harmonic Ballancer/pulley assembly MD141468 Head bolts MD065959
I have seen a few of the others I needed on here. I also got a few others PN's at home that I didn't buy. Maybe when I remember to get them I will update more.
John Pszenyczniak 67 Mustang Coupe 95 Firebird Formula 05 Ram hemi 4x4 91 Montero RS LWB w/ 320k miles before rebuild, 900 down and its still kicking!!!
#196294
10/28/05 07:50 PM
'87 Mitsubishi Montero front axle Snap Rings: MB092882. Shim Kit: MB241229.
Weebur
'97 Jeep Cherokee XJ, Country, Black/Gray Leather, 4.0L, 4WD Command-Track, AW-4 Auto, 3.55:1 Gears, PowerTrax No-Slip Locker, Hi Country Tow Brackets, Spectre Air Filter, 235X75R15 Goodyear Wranglers, 126K miles
