Page 12 of 14 1 2 10 11 12 13 14
Re: Specialized Part Number Repository [Re: CapnCrunch] #196305 01/06/08 12:16 AM
KrzyDav Offline
Trailing arm bushings:
Gen 1 front MB584146
( use these also on gen 2 into gen 1 mod.)
Gen2 front MB809388
Gen 1 and 2 rear press in: MB631492
Panhard bar: MB584166
dave h.
Re: Specialized Part Number Repository [Re: KrzyDav] #196306 01/11/08 09:59 PM
KrzyDav Offline
Crankshaft Front Repair Sleve( speedy sleve) 3.0 12valve
Fel Pro 16273 ( future # 21-2126)
covers up nicks and such on the sealing suface of the crank . Buy 2 cause you'll probably smash the 1st one , unless you've had some practice with these.
dave h.
Re: Specialized Part Number Repository #196307 03/16/08 06:42 AM
MainstreaM Offline
I own a copy of the Dodge 1989 Import Parts Catalog. I took the time to scan it in PDF form. Naturally I did it for the conquest section but the raider is in there as well. Enjoy.
Right click save as is suggested. These are very large files plus it saves on bandwidth. This has been graciously hosted for free by a Starquestclub.com member so please respect his generosity by saving to your PC. They are not in catalog order but are sorted by part groups.
http://www.ilostmymind.com/manuals/1989_Import_Parts_Catalog/
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
Re: Specialized Part Number Repository [Re: MainstreaM] #196308 08/01/08 10:54 PM
Happy Birthday hazy_daze Offline
Some of these are reposts, but I put them together for logic's sake.
First of all, thanks to MainstreaM for the Dodge Parts Manual. That helped me out <img src="/forums/images/graemlins/kewl.gif" alt="" />
Harmonic Balancer/Crank Pulley Mitsu/Dodge P/N MD141468 ~$135
Also, this is available from NAPA in the Balkamp line P/N 600-5324 ~$120ish. I had them both in front of me and can't tell the difference. Weight, dimensions, even paint and timing mark is identical. Giving this P/N as an alternative to the dealer, because it's more readily available.
Crank Bolt Dodge P/N 1101A022 >$1
Washer Mitsu/Dodge P/N MR994412 ~$5
Woodruff Key Mitsu/Dodge P/N MD008959 ~$3
Tensioner/Idler Pulley Mitsu/Dodge P/N MD308882 ~$43
I have also found this available thru NAPA in the Altrom line, P/N 155-3401 ~$36. They come in a GMB box and look exactly like the OE one, except for GMB stamping.
And thanks for your support <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Specialized Part Number Repository #196309 08/20/08 05:34 PM
[Thought I'd add this to help others find the link via Search...]
Factory service manual for many related models can be found in PDF format on MitsubishiLinks.com.
These manuals are the combined effort of all those who work hard to keep the fires burning. We know who we are- the ones who like to march to a different beat. That's why we work so hard on our Mitsus. Use the manuals as you need, for your own needs. They are not for profiteering.
I have seen on fleaBay some of the same scans I have! Don't ruin a good thing by being an <img src="/forums/images/graemlins/butwiggle.gif" alt="" />.
Ride On,
Bill
Re: Specialized Part Number Repository [Re: MontyMcV] #196310 09/23/08 03:50 AM
Ride On,
Bill
***Edit/reply to add keywords FSM and CAPS and WinCAPS...***
Re: Specialized Part Number Repository [Re: MontyMcV] #196311 12/09/08 04:08 AM
justice Offline
Heater hose 95 SR 3.5 DOHC
Goodyear part no 63137
was found to be in stock at my local kragen(checker/shucks) on a sunday..if you cut it in the right place will be close to exact bend and lenghth as OEM.
Good to work with a parts guy that was worth a $hat, that was willing to find it for me <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Specialized Part Number Repository [Re: justice] #196312 12/28/08 10:55 PM
KrzyDav Offline
MB633820 $ 10.40 from Mitsubishiparts.com (Korum Mitsu),WA.
Press in bushings for upper control arms on Gen2.
dave h.
Re: Specialized Part Number Repository *DELETED* [Re: MontyMcV] #196313 12/29/08 09:05 PM
L
lwelsch Offline
Post deleted by off-roader
Re: Specialized Part Number Repository [Re: lwelsch] #196314 12/30/08 04:05 AM
I have found very litlle difference in the 89 FSM and the 91. They turn up on Fleabay from time to time. There's 2 volumes Body & Chassis and Electrical (w/ schematics).
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6565 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-06-23 04:51:30 UTC
