Page 14 of 14 1 2 12 13 14
Re: Specialized Part Number Repository [Re: TrailRaider] #196325 09/20/10 03:07 AM
hazy_daze Offline
GenII front diff breather fitting with hose nipple.
MR176208
This nipple will fit the GenI front diff cover with no modifications. It allows a hose to be put onto the nipple and routed to a higher location.
Enjoy <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Specialized Part Number Repository *DELETED* [Re: hazy_daze] #196326 09/20/10 07:50 PM
MI_Mitsu Offline
Post deleted by off-roader
Re: Specialized Part Number Repository [Re: MI_Mitsu] #196327 01/22/11 03:44 AM
KrzyDav Offline
Old Man EMU numbers
urethane bushings (not available over here, maybe a group buy from Aus. someday).
Gen 1
Lower Front Control Arm:
front-OME SB5240
rear- OME SB5230
R. Trailing Arm:
at frame- OME SB6124
at axle- OME SB6117
Gen.2
Front Lower Control Arm:
front-OME SB5240
rear OMESB6120
rear trailing Arm:
at frame- OME SB6125
at axle- OME SB6117
M.S.
Lower control arm --same as Gen 2
Panhard Bar: 83 on , All- OME SB8112
dave h.
Re: Specialized Part Number Repository [Re: KrzyDav] #196328 01/23/11 01:19 AM
KrzyDav Offline
OME Spring info:
rear coils
Gen 1-LWB OME 910 1 1/4" lift
Gen 2-LWB OME 910 1 1/4"; OME 938 constant rate "expedition H.D."
Mont.Sport OME 911 medium duty; OME 910 2" lift heavy duty
92 on Gen 2 "SWB" OME 911 1 " lift
I think this would work for Gen 1 SWB
Tortion Bars
leaf spring models OME303009
Gen 1 and Gen 2 to '94 OME 303010
Gen 2 94+ OME 303011
dave h.
Re: Specialized Part Number Repository [Re: KrzyDav] #196329 02/04/12 01:55 PM
1998 Mitsubishi Montero (or any Gen II) Generic Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 1157
Front Turn Signal Light Bulb Size: 1157
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 2057
Stop Light Bulb Size: 2057
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: H3-55W
License Plate Light Bulb Size: 5008
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 1157
Rear Sidemarker Light Bulb Size: 168
Ash Tray Light Bulb Size: 74
Step/Courtesy Light Bulb Size: DE3022 or DE3175
Trunk/Cargo Area Light Bulb Size: DE3175
Instrument-General Light Bulb Size: 158 Or 74
Compiled by Grasscat AKA Michael j
Re: Specialized Part Number Repository [Re: off-roader] #196330 02/24/13 11:56 PM
KrzyDav Offline
Relay for main ECU for 89-94 3.0 SOHC 12 valve:
RY401 Standard Ing.
$58.99 Rockauto
dave h.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6279 MB (Peak: 0.6990 MB) Data Comp: Off Server Time: 2026-06-22 14:15:02 UTC
