Re: Specialized Part Number Repository
[Re: TrailRaider]
#196325
09/20/10 03:07 AM
GenII front diff breather fitting with hose nipple.
MR176208
This nipple will fit the GenI front diff cover with no modifications. It allows a hose to be put onto the nipple and routed to a higher location.
Enjoy <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Specialized Part Number Repository *DELETED*
[Re: hazy_daze]
#196326
09/20/10 07:50 PM
Post deleted by off-roader
[Re: MI_Mitsu]
#196327
01/22/11 03:44 AM
Old Man EMU numbers
urethane bushings (not available over here, maybe a group buy from Aus. someday).
Gen 1 Lower Front Control Arm: front-OME SB5240 rear- OME SB5230 R. Trailing Arm: at frame- OME SB6124 at axle- OME SB6117
Gen.2 Front Lower Control Arm: front-OME SB5240 rear OMESB6120
rear trailing Arm: at frame- OME SB6125 at axle- OME SB6117
M.S.
Lower control arm --same as Gen 2
Panhard Bar: 83 on , All- OME SB8112
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#196328
01/23/11 01:19 AM
OME Spring info:
rear coils
Gen 1-LWB OME 910 1 1/4" lift Gen 2-LWB OME 910 1 1/4"; OME 938 constant rate "expedition H.D." Mont.Sport OME 911 medium duty; OME 910 2" lift heavy duty
92 on Gen 2 "SWB" OME 911 1 " lift I think this would work for Gen 1 SWB
Tortion Bars
leaf spring models OME303009 Gen 1 and Gen 2 to '94 OME 303010 Gen 2 94+ OME 303011
[Re: KrzyDav]
#196329
02/04/12 01:55 PM
1998 Mitsubishi Montero (or any Gen II) Generic Light Bulb Size Chart Low Beam Headlight Bulb Size: 9003/HB2 High Beam Headlamp Light Bulb Size: 9003/HB2 Parking Light Bulb Size: 1157 Front Turn Signal Light Bulb Size: 1157 Rear Turn Signal Light Bulb Size: 1156 Tail Light Bulb Size: 2057 Stop Light Bulb Size: 2057 High Mount Stop Light Bulb Size: 921 Fog/Driving Light Bulb Size: H3-55W License Plate Light Bulb Size: 5008 Back Up Light Bulb Size: 1156 Front Side Marker Light Bulb Size: 1157 Rear Sidemarker Light Bulb Size: 168 Ash Tray Light Bulb Size: 74 Step/Courtesy Light Bulb Size: DE3022 or DE3175 Trunk/Cargo Area Light Bulb Size: DE3175 Instrument-General Light Bulb Size: 158 Or 74
-------------------- Compiled by Grasscat AKA Michael j
[Re: off-roader]
#196330
02/24/13 11:56 PM
Relay for main ECU for 89-94 3.0 SOHC 12 valve: . RY401 Standard Ing. $58.99 Rockauto
