Front locker or Limited Slip (88 Mighty Max) #199312 02/17/03 04:16 AM
mwhite Offline OP
I know nobody makes a locker but I have heard of people
putting a starion limited slip diff into the axles, checked archives
there was a thread but it did not say if it worked. Also can a
arb or detroit be modified or any other, also what would be
involed to but a different axle under front end either a ifs or
sa
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: Front locker or Limited Slip (88 Mighty Max) #199313 02/17/03 04:36 AM
An SAS is a major project and mucho $$$$, and I only know of one. He spent (if I remember right) about $19k (yes, that's NINETEEN THOUSAND DOLLARS!) on the swap on a gen2. Granted, he went with brand new parts and professional install, but Jeezus, that's a wad of money. If memory serves, that was a radius arm/coil spring/Dana 60(?) locker swap with crossover steering.
On the Starion lsd, I think Kary (Big Blue) worked it out, but I don't know exactly how, and would like to know, as the IFS front end hasn't failed me yet offroad, and I don't even have trimmed bump stops. I believe that some machining of the lsd carrier is required to fit the Monty housing, and there may also be axle spline count issues. It also looks feasible to me to modify the frame pads the bump stops hit to give a little more articulation, but I don't know the angle limits on the front axle CV joints.
You might do a search and find out more details on the SAS, but that thread got more than a little heated (the guy that did the swap has been MIA ever since) and may have been deep sixed.
<small>[ February 16, 2003, 10:37 PM: Message edited by: fasteddy ]</small>
Re: Front locker or Limited Slip (88 Mighty Max) #199314 02/17/03 04:47 AM
mwhite Offline OP
Just wanted to know about axle swap,
but would like to either find out about modifying
a locker or find a starion lsd. But I would like
to know about any problems in install
Re: Front locker or Limited Slip (88 Mighty Max) #199315 02/17/03 07:08 AM
Yes, Kary "said" he did it, but wants $$$ to tell....so have credit card # ready on hand.... <img border="0" title="" alt="[Embarrassed]" src="images/icons/blush.gif" />
86' and under Starion lsd's is what you're looking for
Re: Front locker or Limited Slip (88 Mighty Max) #199316 02/17/03 11:20 PM
tkal Offline
I was considering having a solid front as well. I belive that if you fab yourself most of the parts and get a used axle it can be done for about $500 open diff. This is just a guess. If the motor I have for my MM works out and I want/can keep the truck I will eventualy do this swap. I will know in about 1-2 months if I am going to do this swap. I am planing on using a dana 44 from a Bronco, I think the diff is on the correct side.
I work at a metal fab shop so I can get brackets bent and weld them up. If someone wants to help me with designe I will fab up a second set of brackes and crap for the volunteer. I was planning on leaf spring. If this intrestes you email me tkal@techemail.com
Over all I think that a swap will work out better in the long run. More parts for lsd or locker more travel and no CV joints or boots to break or crack.
<small>[ February 17, 2003, 05:23 PM: Message edited by: tkal ]</small>
'88 D-50 2.6 needs some love.
Re: Front locker or Limited Slip (88 Mighty Max) #199317 02/18/03 04:03 AM
lordtrunks Offline
I happen to have a front detroit for sale that will work in a 2.6 rig
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Front locker or Limited Slip (88 Mighty Max) #199318 02/18/03 04:38 AM
Charlie Belew Offline
trunks, with everything else that you have done to your rig, why are you selling your Detroit?
That "major project" SAS was done to a Montero Sport.
<small>[ February 17, 2003, 10:39 PM: Message edited by: Charlie Belew ]</small>
None
Re: Front locker or Limited Slip (88 Mighty Max) #199319 02/18/03 05:11 AM
tkal Offline
If I like this motor I am planning on doing the swap anyhow. I am just wondering if anyone wants to help designe the front and make the swap themself.
Re: Front locker or Limited Slip (88 Mighty Max) #199320 02/19/03 12:18 AM
mwhite Offline OP
Lordtrunks how much for the locker??
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.006s) Memory: 0.6257 MB (Peak: 0.7236 MB) Data Comp: Off Server Time: 2026-11-16 01:31:02 UTC
