Check Engine Light during downhill #199765 02/20/03 02:02 PM
kiks Offline OP
Montero SR, 1994 V6,3.5cc, Automatic Transmission.
The Check Engine Light comes on during downhill and engaged in lower gear for engine brake. After about 1 hour of driving on even roads, light goes out.
This does not happen on uphill roads and flat roads.
Please advise on what I should check out first. The new sensors I have replaced are the Oxygen Sensor and the Engine Coolant Temp. sensor. The problem keeps appearing again.
Thanks in advance.
Frank
Montero SR, 3.5 , 1995 model, ABS, Rear Differential Lock
Re: Check Engine Light during downhill #199766 02/20/03 05:19 PM
I would start by getting the code from the ECU and see what it says.
Re: Check Engine Light during downhill #199767 02/20/03 05:22 PM
Might be a coolant sensor...
or a O2 sensor....it might be cooling down too much and producing that error also...
Re: Check Engine Light during downhill #199768 02/20/03 11:14 PM
kiks Offline OP
Thanks Scottie and Jason
Re: Check Engine Light during downhill #199769 02/21/03 05:40 AM
Or an injector leaking under very high manifold vacuum, if the code is for excessive richness, but I don't know the code sceme for this engine.
Re: Check Engine Light during downhill #199770 02/22/03 12:24 PM
kiks Offline OP
Could a defective intake plenum gasket be the culprit? The former owner told me that he replaced the spark plugs, had to take out the plenum. He did not use a new gasket for the plenum. Could this be it?
Re: Check Engine Light during downhill #199771 02/22/03 03:49 PM
pmontero Offline
kiks,
There are a lot of things it could be including the whole computer (in my case) You really need to pull the code before you proceed any further. Otherwise, you will be totally shooting in the dark...
Powell
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6105 MB (Peak: 0.6864 MB) Data Comp: Off Server Time: 2026-06-22 06:23:24 UTC
