A/T Temp Sensor
#200263
02/24/03 07:53 PM
I need to replace the A/T temp sensor, and I was wondering where one could be obtained at the best price? Is this a stealership only part? Additionally, are there any concerns or tricks to replacing this? Thanks!
1991 3.0 Montero... <small>[ February 24, 2003, 03:18 PM: Message edited by: toyota87 ]</small>
1987 Toyota 4x4 Long Bed Deluxe
Re: A/T Temp Sensor
#200264
02/24/03 10:53 PM
You could just ground the wire, because the "sensor" is just a normally closed temp switch that opens and breaks the od switch ground circuit when the engine heat gets above the trip limit. Nothing special on the removal or install, except use thread sealer and don't take the tapered threads too tight.
PHP: 7.4.33 Page Time: 0.016s Queries: 14 (0.012s) Memory: 0.5869 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-11-18 07:26:28 UTCValid HTML 5 and Valid CSS
