Failed emissions...NOx through the roof
#210170
05/29/03 03:02 AM
Well, my new '90 RS just failed inspection. Everything was well within spec, except for the crazy NOx reading. I don't have the papers in front of me, but passing was in the 1100 range, and I scored a 2300 <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> . My first thought is to replace the cataltic converter, but what coulds have plugged it up this bad? I'm going to get a new cat, and exhaust this week, probably going with 2 1/4 or 2 1/2 plumbing depending on fit. Any recommendations on mufflers, or resonators. Would love to get the most power out of the engine, but not at the expense of lots of noise. On a side, my Raider also failed miserably. During the dyno test, it was smoking so bad they actually stopped the test and failed it for visible smoke emissions. Doubt my sister will want to sink $$ into having it fixed. How hard would it be for an average joe who knows a socket from a crowbar to do?
Thanks in advance for all the help, ted.
99 trooper
somewhere in nj
Re: Failed emissions...NOx through the roof
#210171
05/29/03 03:09 AM
Whoa Nelly! Don't spend a wad on the cat and exhaust yet. Chances are that high rating is from carbon in your EGR valve, pipe and plenum. The EGR valve could also not be operating properly. Get it checked first and cleaned or replaced depending on results.
I would do this first before replacing the cat.
Powell
#210172
05/29/03 03:18 AM
NOx emissions are formed when there are very high combustion temps, like from a lean mixture. Three way cats and egr are what control NOx, but make sure the fuel system is ok - what was your CO and CO+CO2 and HC?
#210173
05/29/03 03:58 AM
Nothing like jumping the gun. After doing a little searching here, I thought that the EGR could only cause slight changes in the NOx levels. Either way, here are the reading for the other measures: STANDARD READING HC 174 103 CO 1.56% 0.76% CO2 14.3% O2 0.5%
Thanks again for all the help and tips. Brakes are getting worked on this week, KYB's by this weekend.
Ted.
99 trooper
somewhere in nj
#210174
05/30/03 04:53 AM
Mine failed w/ high emissions, but I also had "extremely high temp" in the comb. chamber, so we replaced cat, and water pump, then we passed <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
#210175
05/30/03 01:10 PM
I just noticed that this was your '90 Monty that failed. I have a '90 engine disassembled to the short block and I don't think it has an EGR valve.
Post when you have results and a passing score...
Powell
#210176
05/30/03 03:12 PM
The EGR valve is not on all Monty's, I know its on CA models, cause I have one. If you do have one, its bolted to the intake plenum on the driverside, with a tube running to it from the exhaust manifold. Typically the valve does not fail. What usually happens is the plenum gets plugged, and is a real PITA to clean out cause the EGR passage has a 180 deg bend. I had to remove my plenum, and have it tanked and pressure washed. Real PITA.
Might want to read my post on this:http://www.4x4wire.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=69;t=007577
Good Luck
#210177
05/30/03 03:13 PM
