Vibration help with 1994 Montero LS #210898 06/07/03 12:11 AM
I get a roaring noise starting about 60 mpg to 70 mpg and then it seems to disappear. This is when the vibration start to kick in and I can see it shaking the mirrors slightly. I am thinking bent drive shaft ?? but I am not sure. I bought this Montero about a year ago so I am not sure about prior history. I can't see any markings on the drive shaft that would indicate damage.... any suggestions thanks Mike Cunningham
Re: Vibration help with 1994 Montero LS #210899 06/07/03 12:31 AM
kiks Offline
Hello,
Try having the front wheels balanced. I would start with the simplest checks first.
Good Luck.
Kiks
Montero SR, 3.5 , 1995 model, ABS, Rear Differential Lock
Re: Vibration help with 1994 Montero LS #210900 06/07/03 12:58 AM
MontyGrant Offline
does it happen when you get to about 3100rpms and then as you let off the gas a little the roaring noise ceases and the rpms "settle" at 3000? is it anything like that?
if it happens when you hit 60 or 70 but goes away a few seconds later i think it would be transmission related...
does your tranny sometimes downshift at inappropriate times? like going up a hill?
-Grant
'98 Montero with 135k miles
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.5896 MB (Peak: 0.6425 MB) Data Comp: Off Server Time: 2026-06-21 13:02:28 UTC
