Re: The best all around Engine Swap?
#21571
02/28/03 05:31 AM
I only use the engine ECU, and splice the connectors together, but I keep the plugs on either side, or use another plug to keep it plug n' play.
The tach, I used the supra tach and fit it into the 4runner tach, and you can barely tell. Guy in NC said he hooked up the stock tach and it worked. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
It is better to make torque at high rpm than at low rpm, because you can take advtage of gearing. ---------------------------------------------------------------- www.supracharged.com1994 4runner - SAS, 38 TSL's, Turbo 7MGTE swap, Turbo Tranny Dual T-case, D44/D60 ront/rear
#21572
03/01/03 06:18 AM
Rob, how high does the Supra tach read, and whats its redline?
#21573
03/02/03 02:34 AM
I'm using a V6 tach, it works. Not sure if Redline is the same.You can see the V6 printed on it. the 4cyl are blank. Tis is from a Auto 89 4runner. I just swapped the Tac into my cluster. only a few screws nothing hard. <img src="http://home.fuse.net/PaulE/tach.jpg" alt=" - " />
#21574
03/04/03 06:54 AM
Ok I have one question on this.. I have an 85 runner and was just going to go the 7m-ge route so I wouldnt have to mess with the IC.. but if I dont want to go over stock boost can I skip that part of the process anyway? Basically will I have to put on an IC if I dont intend to do more than stock with the 7m-gte? Also whatg is being done for the cooling on this? From what I gather the mechanical fan should give way to an elctrical.. but what radiator os best? and therefore what fan should I go with?
#21575
03/04/03 08:09 AM
Paul...
what does your oil pressure gauge read?? i think mine is off or i have really low pressure.
i have the SR5 cluster swap in front of a 897mgte
it reads well below the first line at idle and just above it when revving
thanks
89 4runner V6 33 MT/R GoodYear,the only way to go. open front and e-locker rear.4:88....Truck's needs are deeper than my wallet. so i got another truck <img src="/forums/images/graemlins/smile.gif" alt="" /> 85 4R I6 T 35 TRD rear dual case 4.56 lets go wheeling :P
#21576
03/18/03 07:56 PM
I have a 91 V6 manual, how difficult would it be for me to put in an 7M-GTE engine in? would it be any different then the 4 cyl engines?
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6138 MB (Peak: 0.6821 MB) Data Comp: Off Server Time: 2026-06-20 20:25:03 UTCValid HTML 5 and Valid CSS
