Re: Starter troubles #216505 10/27/02 09:23 PM
Dave Scott Offline
ok, when my timing belt went, it still started once or twice more, but then died again really quick, then it wouldn't start again. it was almost like it wanted to start really bad, but wouldn't, anyway, if it is the timing belt, it's a bitch to change and i mean it. you have to remove everything from the front half of the engine just to get to it, that includes all the belts and pulleys, water neck and everything attached to that, the fan, the radiator shroud, and the a/c compressor needs to be loosened and moved enough to get the cover off and get your hands in there. i refused to do it myself.
if it is the timing belt, it may be possible that the previous owner took the vehicle to PepBoys to have the water pump replaced. if that is the case, Pepboys was using the wrong part. they were replacing DOHC water pumps in Sportages with SOHC Bosch water pumps. the timing wheel is completely different and that's what chewed my timing up. don't worry, i proved it and they paid the bill, but it just sucked. the bolt pattern is exactly the same and the water passages are so dang close that you wouldn't know the difference unless you saw them both side-by-side from the front. the wheel is bigger on the SOHC pump and the teeth are bigger and spread out further than the DOHC belt. it cost a fortune (for me) to have the timing belt and water pump replaced ($700.00), and that was in Nowheresville middle of Texas (who, by the way, knew more about how to work on my Kia than any of the freakin' dealers in San Antonio), so i figure, maybe half that for the timing belt alone, maybe less, but most of it is labor, and believe me, for all that, it's still a little cheap.
if it isn't your timing belt, i don't have an answer for you because i haven't run into that yet.
as far as determining which is the problem? i don't know, i didn't have a choice in the matter when it happened to me, only wrecker in town that would run at midnight and the only garage in town.
dave <img border="0" alt="[Satan]" title="" src="graemlins/satan.gif" />
Re: Starter troubles #216506 10/31/02 02:04 AM
Explorerguy Offline OP
O.K. can't figure this out.
I haven't worked on the Kia since the weekend since we have had snow and cold weather, but tonight I had to move it so I could get the Explorer out. Since I was just going to move it back a little I thought I would try starting it so I put the key in and turn the motor and "IT STARTED"!!!!
So explain this one to me, why I couldn't get it started before and tonight it started right up???
Anyway I backed it up, backed the Explorer up and put the Kia in first and shut it off.
1994 Ford Explorer 5.5 Superlift, 35's no-slip in the rear, lots of custom parts ( sliders, tire rack & more)
2003 Kia Sorento
1987 Suzuki Samurai for our son and wife
Re: Starter troubles #216507 10/31/02 04:30 AM
okay, its not the timing belt. you've got a bum starter drive. its a simple fix, get a rebuilt starter
matt
Re: Starter troubles #216508 11/01/02 06:28 AM
Dave Scott Offline
all my work gone to waste........... i agree, most likely the starter.
ps- check with Subaru, Suzuki and Kia Auto Parts Recyclers
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6045 MB (Peak: 0.6635 MB) Data Comp: Off Server Time: 2026-06-23 21:15:04 UTC
