Re: ABS Light??
#220082
07/04/03 06:19 PM
have you checked the ABS sensor on the rear axle? this sometimes gets yanked loose by being caught on a object passing under the vehicle. it is a wire that goes to the top of the rear differential on the engine side.
Re: ABS Light??
#220083
07/04/03 07:22 PM
rear passenger drum...nope it doesnt look good gonna have to fix rear seal and brake cylinder
<img src="http://ladyfrog.0catch.com/rear%20pass%20drum.jpg" alt=" - " />
LadyFrog
I miss my little Kia
Re: ABS Light??
#220084
07/05/03 12:22 PM
Kia Moderator Emeritus
Yea, that's not looking good. I'd have to agree that the rear axle seal has seen better days.
And if the brake cylinder was leaking too and needs a rebuild you should flush out all the old brake fluid and go new. It probably absorbed moisture and like Gary said above will make the brakes soft.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
Re: ABS Light??
#220085
07/05/03 12:30 PM
I also noticed...it looks like one of the axle nuts is loose and has been for a long time. It's not seated like the other ones that are visible.
Re: ABS Light??
#220086
07/06/03 05:06 AM
I hadn't even noticed the nut was too busy looking at all the goober ...will have to go take a look
thanks
LadyFrog
Re: ABS Light??
#220087
07/06/03 08:17 PM
if i remember correctly there is one stud shorter than the others. if that is correct, the nut is not loose.
Re: ABS Light??
#220088
07/07/03 12:58 AM
yep took a look at it...not loose just short
LadyFrog
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.6169 MB (Peak: 0.6930 MB) Data Comp: Off Server Time: 2026-06-17 05:20:17 UTCValid HTML 5 and Valid CSS
