Page 4 of 4 1 2 3 4
Re: ABS Light?? #220082 07/04/03 06:19 PM
have you checked the ABS sensor on the rear axle? this sometimes gets yanked loose by being caught on a object passing under the vehicle. it is a wire that goes to the top of the rear differential on the engine side.
Re: ABS Light?? #220083 07/04/03 07:22 PM
LadyFrog Offline OP
rear passenger drum...nope it doesnt look good
gonna have to fix rear seal and brake cylinder
<img src="http://ladyfrog.0catch.com/rear%20pass%20drum.jpg" alt=" - " />
LadyFrog
I miss my little Kia
Re: ABS Light?? #220084 07/05/03 12:22 PM
Axe Man Offline
Kia Moderator Emeritus
Yea, that's not looking good. I'd have to agree that the rear axle seal has seen better days.
And if the brake cylinder was leaking too and needs a rebuild you should flush out all the old brake fluid and go new. It probably absorbed moisture and like Gary said above will make the brakes soft.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: ABS Light?? #220085 07/05/03 12:30 PM
Axe Man Offline
I also noticed...it looks like one of the axle nuts is loose and has been for a long time. It's not seated like the other ones that are visible.
Re: ABS Light?? #220086 07/06/03 05:06 AM
LadyFrog Offline OP
I hadn't even noticed the nut was too busy looking at all the goober
...will have to go take a look
thanks
LadyFrog
Re: ABS Light?? #220087 07/06/03 08:17 PM
if i remember correctly there is one stud shorter than the others. if that is correct, the nut is not loose.
Re: ABS Light?? #220088 07/07/03 12:58 AM
LadyFrog Offline OP
yep took a look at it...not loose just short
LadyFrog
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6161 MB (Peak: 0.7085 MB) Data Comp: Off Server Time: 2026-06-13 16:01:20 UTC
