t100 brakes
#229499
04/19/03 05:48 AM
what is involved in putting t100 rotors and t100 calipers into a 94 pickup? is it a direct bolt in?
what about the tundra brakes? are the tundra brakes beefier and will they fit the pickup?
thanks.
stock 1994 Toyota 4x4 XtraCab v6 SR5 pickup
Re: t100 brakes
#229500
04/19/03 01:43 PM
i think they are the same. the IFS is all the same, so i cannot imagine why the brakes would not bolt on.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
Re: t100 brakes
#229501
04/20/03 03:17 AM
Re: t100 brakes
#229502
04/21/03 04:36 PM
Toyota Moderator
The rotors are thicker on the T100 (24mm vs. 18mm), and the calipers are built to match, but if you swapped them both in, I don't see why they wouldn't bolt right up. <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: t100 brakes
#229503
04/22/03 05:05 AM
I am helping Churnd (on the boards) replace his rotors and they are not the same (as ErikB stated). He has a 94 Mini also. The T's are thicker. As far as the swap, wonder if the larger T100 calipers are a direct bolt up (do the holes line up?) The rotors might work with the hubs but the calipers might be a different story.
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6020 MB (Peak: 0.6648 MB) Data Comp: Off Server Time: 2026-06-25 09:11:29 UTCValid HTML 5 and Valid CSS
