Lock with remote #229963 05/08/03 10:45 PM
P
Postal Bill Offline OP
If I lock my 01 Tundra with the remote, why can't I use the key to open the door and start the vehicle? If I do this the alarm goes off when I open the door and the engine will not start. Help!
Growing OLD is mandatory
Growing UP is optional
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Lock with remote #229964 05/08/03 10:52 PM
jroc Offline
you answered your own Q.....that activates the alarm also.......
Re: Lock with remote #229965 05/08/03 11:12 PM
I had the same problem with a vehicle I had with a stock alarm. If you lock it with the remote, you could only unlock it with the remote. If you locked it with the key you could unlock it with remote or key. It sucked when the remote wouldn't work. I would have to stand outside pressing the button for about 5 minutes. It wasn't a Toyota though. Don't know if they are alike.
<small>[ May 08, 2003, 06:14 PM: Message edited by: JKendrick ]</small>
Re: Lock with remote #229966 05/08/03 11:59 PM
By pushing the button on the remote you are not only locking the doors but you are also activating the alarm system. So you have to use the remote to unlock/disarm the truck. If for some reason the remote does not work you can use the key to get in, and you have to turn the ignition key on and off like five times to disarm the alarm. It tells you all this good stuff in the owners manual. As far as I know all alarm systems are like this, aftermarket or factory.
Later, Ryan
Re: Lock with remote #229967 05/09/03 12:22 AM
Kookadala Offline
If I were you, I would permenantly disable the alarm. Mankinds stupidest invention! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Lock with remote #229968 05/09/03 01:05 AM
P
Thanks for the replies. My wifes 4 Runner is not like that, you can lock with remote and then open the door with the key and start the engine.But that key probably has a chip in it. I bought this Tundra from an independent dealer and did not get a manual, so thanks for the heads up about disarming the alarm in the ignition. I'll try that. <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" />
2001 Tundra
2001 4 Runner
1984 Corvette
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.6062 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-06-20 02:55:53 UTC
