Re: Changing oil...anything to keep in mind?
#230622
06/05/03 09:03 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by MR24Shoe: <strong>How about Jack Points?
Where to stick the jack to get it up...where to put the jack stands to hold it up? Obviously this could be done many ways...but if there's a "best way", I'd like to know....</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">jack? who needs a jack? now i do need a short step ladder to work in the engine bay. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
#230623
06/06/03 01:17 AM
Where to stick the jack to get it up...where to put the jack stands to hold it up? Obviously this could be done many ways...but if there's a "best way", I'd like to know....</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">It really depends on what you're trying to get at under there & what kind of jack you're using.
If you're using the little factory bottle jack (and you're not doing suspension or steering work), place it under the lower control arm; you'll see a nipple, about the size of a quarter... Fits right into the head on the bottle jack.
If you're using a floor jack, go for either the above or any portion of exposed frame... No real difference.
If you're using a highlift, go for the bumpers... (or your nerf bars if you have 'em)
Of course, best practice is to place it where it won't slip & squish you. <img border="0" alt="[Shiner]" title="" src="graemlins/shiner.gif" /> <small>[ June 05, 2003, 08:18 PM: Message edited by: 4xGeek ]</small>
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
#230624
06/06/03 04:07 AM
It's done. Piece of cake. Took about .5 hr...including wiping up multiple spills here and there ;-)
Didn't have to jack it up...taking the skid plate off helped a lot too.
Thanks for all the advice!
shoe
1996 Toyota T100 4x4 SR5 V6 1971 Datsun 240Z
#230625
06/06/03 05:27 AM
Phew. I thought you were back here asking more questions, and someone was gonna have to scream go change your oil already <img src="http://www.handykult.de/plaudersmilies.de/happy/xyxthumbs.gif" alt=" - " />
For jackstands, under the front lower crossmember and inboard of the rear spring perches, right on the tube. <small>[ June 06, 2003, 12:28 AM: Message edited by: adam ]</small>
~Adam  96 T100: D44, lockers and stuff
#230626
06/06/03 05:50 AM
One way to minimize the mess when you loosen the oil filter is to make a catch basin from the bottom of an old coolant jug or other appropriate container. I think I made one out of the bottom of a gallon milk jug. Just stick it right under the filter and you'll find that keeps the upside down oil filter mess to a minimum.
--speedy White '98 T100 SR5 4x4 ExCab Auto - wrecked. 2008 Honda Ridgeline RTS replaced the T100.
#230627
06/06/03 02:51 PM
Yeah, I'll definitely do something next time. My nail trick didn't seem to work too well, or I didn't give it enough time. Something I did do, after all was said and (I thought) done... I tried starting, and it started, but immediately died. I was like "crrraaaap. Now what". So I started again, and it stayed this time. Went through this a couple times...then I notice the CEL was on, and it clicked. I forgot to plug that wire back into the air filter box after checking my filter. Plugged it back in and it fired up like a champ! On a positive note, I found a K&N filter in the box...which iz nice. Thanks again everyone!
#230628
06/06/03 04:16 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by MR24Shoe: <strong>Something I did do, after all was said and (I thought) done... I tried starting, and it started, but immediately died. I was like "crrraaaap. Now what". So I started again, and it stayed this time. Went through this a couple times...then I notice the CEL was on, and it clicked. I forgot to plug that wire back into the air filter box after checking my filter. Plugged it back in and it fired up like a champ! </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">hahahahahahahahhahahahahaha I did that once too.
#230629
06/06/03 10:54 PM
k & n filter box? Can you give me some more info on this.
Also with spills, something that i'm particularly fond of is castro superclean. It's a highly concentrated purple solution. after the spillage wipe it well, spray it with the superclean, dilute to specifications or leave a bit stronger and spray the underside let it sit for 5 min and hose off...i'll look new!! if you don't dilute it, it'll eat thru paint hoses and everything else. Use it to clean the truck quad and jeep. Works better than simple green. My o2 cents
#230630
06/07/03 12:28 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by blatant: <strong>k & n filter box? Can you give me some more info on this.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I think you misread... He found a K&N filter 'in' the box... <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
