coil spring spacers #234713 06/05/03 06:05 PM
tacomajsc Offline OP
I am wanting to make my own coil spring spacer and was wondering if any one else has tried this. I am going to use Tuff Country 3" add-a-leafs in the rear and the spacers in the front. By the way i have a 98 Tacoma.
My signature has been removed.
Re: coil spring spacers #234714 06/06/03 05:54 AM
Mark in AZ Offline
Toyota Moderator
You know, I have never seen a drawing for them, but it can't be too difficult. I think if you do the machining, you will come out ahead. But if you have to pay someone, I think the Cornfeds will be cheaper.
Exploring in a T4R Ltd V8
Re: coil spring spacers #234715 06/11/03 06:11 PM
I have done some searching on the net and found a site that sells the spacers. It shows a close up pic and they looh east to make. Looks like you could cut two peices of place out the same size as your mounts and weld one on each side of a peice of pipe and just make it the size you want. With the center cut out for the shock of course. I would post the web site but i am not sure on you rules. The cornfeds do have some good prices, i think i will get my diff drop from them.
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.005s) Memory: 0.5911 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-11-01 19:42:23 UTC
