Re: Help! rear brakes, piston won't retract #236878 06/05/04 12:13 AM
True stories....fronts are compressed and rear are turned. Been there/done that too many times in the last few years or so.
Re: Help! rear brakes, piston won't retract #236879 06/07/04 06:36 PM
The first time I did a brake job on my trooper I tried to compress the rears with a c-clamp. I thought the caliper was frozen. After I took the whole damn thing apart I checked the book and discovered that the piston had to be screwed in <img src="/forums/images/graemlins/shiner.gif" alt="" /> The book was not very clear.
I suppose they had a good reason for doing it that way, but it is definitely a trap for the unwary.
Jim
Re: Help! rear brakes, piston won't retract [Re: MeatWagon] #236880 06/07/04 10:58 PM
pucci Offline
There is a handy tool (the "cube"), which takes all the fun out of it.
Oh yes, stabbing yourself in the hand with needle nose pliers is so much fun. <img src="/forums/images/graemlins/shiner.gif" alt="" /> Anyone with a 1G Trooper that does their own work owes it to themselves to avoid such good times & pick up this cheap tool:
Immobilizing the caliper while turning, as Meat stated, is key. I had a problem with the pistons in mine not wanting to budge and needed to use a breaker bar with the cube to get them to move. I currently have the problem of a sticking e-brake and I suspect it has to do with the auto adjusters being siezed.
2.6 Trooper
2.0 Impulse Turbo
Re: Help! rear brakes, piston won't retract [Re: pucci] #236881 06/07/04 11:25 PM
sweater Offline
I've got the same issue with my Trooper. Is this a replace the caliper sort of thing? Or a rebuild of something? (read: what's the cheapest route to fixing this?)
Re: Help! rear brakes, piston won't retract [Re: pucci] #236882 06/10/04 02:31 PM
I also have a sticking E-break and mine are less than a year old. I've used "Kroil" (WD40 x 10) in my cables to release them and discovered that it is the return spring that is faulty. I tried everything to make that spring do its thing but it is one old crusty son of a <img src="/forums/images/graemlins/smile.gif" alt="" />. I've decided that I will get my E break system functioning properly and then remove the cables and store them in my house till inspection time. My troop is an automatic so I never use them and they sieze up every year. That should solve my problem <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Help! rear brakes, piston won't retract #236883 06/10/04 11:31 PM
pucci Offline
I initially thought that was part of my problem. I replaced the spring (#8-94238-596-0) and the plastic bushings (#8-94479-600-2) but still the same situation.
2.6 Trooper
2.0 Impulse Turbo
Re: Help! rear brakes, piston won't retract [Re: pucci] #236884 06/12/04 03:17 AM
just got done doing my brakes. are second gen troopers differant my rear and my front calipers pushed right in easly with a small c clamp? is it possible that something is broken inside both my rear calipers?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6152 MB (Peak: 0.6940 MB) Data Comp: Off Server Time: 2026-06-17 13:03:16 UTC
