Indiglo Gauge install help #237234 07/02/03 05:38 AM
I installed the overlays I'm just trying to figure out how to wire them. I ground the gauges I just need to find a power source. Thanks for your help
Re: Indiglo Gauge install help #237235 07/02/03 05:39 AM
Might help if I tell you what kind of vehicle lol. 99' Rodeo V6
Re: Indiglo Gauge install help #237236 07/01/03 09:35 PM
JasonB Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by dtexan:
<strong>I installed the overlays I'm just trying to figure out how to wire them. I ground the gauges I just need to find a power source. Thanks for your help</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">do you need +12 only when the lights are on? If so, you need to tap an illumination wire either the bulbs that normally light you up (solder to the board for this one) or tap the illumination wire on the stereo using a relay.
adding life to my days...not days to my life...and LOVING it.
Worlds best BBQ Rub here...
Re: Indiglo Gauge install help #237237 07/03/03 08:48 PM
cnpalmer Offline
The easiest way is to tap the wire in the driver's kick panel, I want to say it's the red/black one in the bottom white 20-pin plug assembly.
This will give you power to your gauges when you turn on your parking lights or headlights only, and they are off when your lights are off.
I can get the right wire if you need it, all I'll do is remove my kick panel real quick or you can get a $3.00 tester from Radio Shack that will light up when you test the pin in the assembly and your headlights are on, that's what I did.
2004 TJ "X" - 6cyl.|5 speed|2.5" Skyjacker Lift|Skyjacker Nitro Shocks|Chaparral 33's|Cragar Soft 8's
Re: Indiglo Gauge install help #237238 07/04/03 03:56 AM
9
99RodeoDude Offline
What about tapping into the feed wire to your factory Instrument Illumination lights? It's the Green w/Red stipe one (NOT the red w/green stipe) that feeds the potentiometer for adjusting the intensity of those lights. On/off when you need it.
HTH,
Dave
'99 Rodeo LS 4WD,
3 Indy 4x susp.lift w/OME 912s & SkyJackers, Aisin hubs, KC fog lights, KC driving lights, 255/75-15 Pirelli Scorpion AT's
Re: Indiglo Gauge install help #237239 07/07/03 04:45 PM
JasonB Offline
Good call dave...
the wiring diag's at bulldog's website:
http://www.bulldogsecurity.com/wires2/showmodels.asp?modelid=14366&Submit1=Get+Wiring+Details
says this is a grn/red that tests pos. located in the drivers side kick...i think the one on the knob would be easier to get to.
<small>[ July 07, 2003, 11:55 AM: Message edited by: JasonB ]</small>
PHP: 7.4.33 Page Time: 0.005s Queries: 14 (0.003s) Memory: 0.6073 MB (Peak: 0.6727 MB) Data Comp: Off Server Time: 2026-06-10 11:29:14 UTC
