3.4 engine mod vs. original ECM
#239404
05/26/02 06:53 AM
I've posted a couple of questions lately regarding my 2.8 to 3.4 change over plans, got some good and useful feed back, however I still can't get a clear answer on the issue of the original computer(ECM). I would like to find out from those of you who did it what exactly was required in a way of mating new engine with the original controler, or maybe a different one was needed all together. I've read some conflicting stories on this specific issue <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> As added info: I want put in 3.4 engine with 4.3 TBI into my 91' Trooper LS Auto. Help me out guys, I realy need some hints on this one. Thanks in advance for all inputs <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
ElBarto.
Good judgement comes from a lot of experience and a lot of that comes from Bad judgement
3.4L 91' Trooper 4.3 TBI, Airmax 1" TB spacer
Re: 3.4 engine mod vs. original ECM
#239405
05/26/02 07:53 AM
The original computer works just fine. The 2.8 to 3.4 swap is a basic long block swap. With drill and tap the holes for the starter. With a good O2 sensor and 4.3 tbi, your computer won't know the difference.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
#239406
05/26/02 08:30 AM
THANK YOU, finally a straight answer. One last question on subject of fuel economy, any noticable changes after the change-over?
ElBarto.
#239407
05/28/02 07:36 PM
- Where did you get or plan to get your 3.4 engine from?
- is it brand new?
- how much did you pay for it?
- if I where to ask for a 3.4 engine to replace my 2.8, which type of 3.4 should I ask for?
Thank you for all your help and patience,
Octavio
#239408
05/29/02 03:41 AM
If you looking for info regarding the 2.8 to 3.4 engine swap there is a lot of it on this bulletin board as well as ITOG. For starters the 3.4 engine comes from model year 93' to 95' Camaro or Firebird its also refered to as VIN "S". Provided that you have Auto transmission in your Trooper its a direct bolt-on application. On the outside it is virtually same engine with the exception of the starter which has to be swaped over to the driver side for Isuzu application. Most of the junk yards will have the type of engine or you can look on the net for it. Either way they range in price between 300 and 600 hundred $ depending on the condition of the engine. I myself got a cheaper one because am planning to rebuild it from the ground up so I know what I got on the inside but you may want to just get a newer power plant so all you have to do is install it. No matter how you look at it is a great upgrade for the tired old 2.8, it will actually provide the truck with an adequate power it should've come with form the begining. Highly recomended modification. If you want some more info on the subject look around in the old posting on this site or e-mail me and I'll send you some of the stuff I got from other guys. Happy hunting,
ElBarto.
#239409
05/29/02 06:05 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by ElBarto: <strong>Provided that you have Auto transmission in your Trooper its a direct bolt-on application. </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I have never heard anything about the tranny type making a difference. Did I miss something?
-Joel '02 Trooper S The dog-mobile.
'90 Trooper LS Dearly departed after 13 years in the family. Donated to WAMU Radio in DC.
#239410
05/29/02 04:35 PM
It works just fine with the manual. Just off the top of my head I know of three 3.4s in Troopers with the 5 speed - Perosi, Wombat and me.
#239411
05/29/02 04:46 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by J Paget: <strong>It works just fine with the manual. Just off the top of my head I know of three 3.4s in Troopers with the 5 speed - Perosi, Wombat and me.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Add one more to the list.
Ed
